Electrical Problem Draining Battery
Old Apr 23, 2005 | 09:05 PM
jimsc6's Avatar
jimsc6
Cruise-In VII Veteran
Default Electrical Problem Draining Battery
Good Evening Everyone,
I'm having a problem with my C6 that the battery completely drained on me after 3 days of not being driven. After charging the battery with a battery tender plus I'm starting to hear something running in my dash, almost the sound of a clock ticking. The car is a 6 speed, and yes I did properly parked in reverse with the emergency brake engaged. Any ideas?
Old Apr 23, 2005 | 11:36 PM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
i had the same problem except it was dead after two days of not being driven. I wondering if it wasn't fully in reverse. I wonder where the "cut off" sensor is located in the reverse gate. Did you put it in reverse then actually back up just a tad or did you just put it in reverse and get out ?
i've noticed sometimes it dosen't go fully into reverse, it slids into the gate but won't go fully into position.
I've begun to do the put into reverse, roll it back just a tad and haven't had any more problems, thus far.
Old Apr 24, 2005 | 12:13 AM
Braced's Avatar
Braced
Sounds like it's time to see your local chevy dealer. Something is obviously not turning off. Keep it on the charger between drives until you get it looked at.
Good Luck.
Old Apr 24, 2005 | 06:45 AM
blittle's Avatar
blittle
Check this out......someone else on the forum brought this to my attention and it will be the first thing I install on my new C6!
http://www.prioritystart.com/
Old Apr 24, 2005 | 09:41 AM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
If there is a problem with the electrical system in the car, have a dealer repair it. Don't cover it up with this device. This device is not designed to fix the problem, it is designed to prevent a battery from draining due to loads such as cell phones, GPS units left on when the car is turned off.
An electrical problem in the car can cause more damage than just a dead battery.
I considered installing something like this in my Jeep, due to the fact I travel miles from civilization in the desert, and have two GPS units running in the Jeep, along with an electric cooler, CB; not because of an electrical problem in the Jeep.
It's your car, but an electrical problem can grow.
Old Apr 24, 2005 | 11:13 AM
archtop's Avatar
archtop
Make sure you use the proper procedure for shutdown.
With the engine still running put the car in reverse then shut down.
If you shut down then put the car in reverse some computer functions may still remain on and drain the battery.Got that information from my dealer tech who called the chevy tech dept. and faxed him the procedure which he showed to me.I was having a similar problem ( dead battery after 2-3 days) since I've been doing the "turn Off" procedure I haven't had a problem.Went away for a week and she started right up.
Old Apr 24, 2005 | 12:08 PM
C8-Vette's Avatar
C8-Vette
Old Apr 24, 2005 | 12:10 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
great tip
Old Apr 24, 2005 | 12:45 PM
Corvette Junkie's Avatar
Corvette Junkie
Night Race Blue 427
From: Muncie, Indiana ...... Can I buy an amplifier on time ... I ani't got no money now but I'll pay you before I die
I've shut my C6 off without it being in reverse first let it sit 2 to 3 weeks before starting it again with no battery problem.
Old Apr 24, 2005 | 01:11 PM
archtop's Avatar
archtop
Weird,wonder why they would tell me the procedure was real important?
To Electrical Problem Draining Battery
