Break In
Old Apr 29, 2005 | 08:39 PM
nascar5212002's Avatar
nascar5212002
Default Break In
I will be picking up my new c-6 in three weeks. what is the proper way to break it in? (drive it hard, easy, very in speeds, pull some Gs? )
need some advice.
Old Apr 29, 2005 | 08:43 PM
toedoc's Avatar
toedoc
Follow the recomended procedure from GM, lots of posts on this, a search will be helpful
Old Apr 29, 2005 | 08:46 PM
C6 Girl's Avatar
C6 Girl
St. Jude Donor '05
when r u picking up ur car?
Old Apr 29, 2005 | 08:49 PM
nascar5212002
HOPEFULLY THE 26TH MAY Y?
Old Apr 29, 2005 | 08:58 PM
C6 Girl's Avatar
C6 Girl
St. Jude Donor '05
if its in BG i'll be there for mine on the 16th
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
For what I did, top speed first 0-500 miles around the 55 MPH range, not much pass 65. Vary speed and rpm's. Just took it easy. Gave a chance to understand the C-6. (for rear axial parts)
500-1,000 medium to light driving.
After 1,000 miles and oil change, hit it pretty HARD!
Now hitting real hard! 1,300 miles and not one problem. Lucky I guess.
C-6 made in Jan 05, vin 13,000 appox.
Old Apr 29, 2005 | 09:00 PM
Vette_DD's Avatar
Vette_DD
Page 2-19 of your owner's manual.
Old Apr 29, 2005 | 09:16 PM
Akro's Avatar
Akro
Vary the speeds and keep it below 65 or so -it's just too hard to keep it under 55 - you might get run over.
Old Apr 29, 2005 | 09:39 PM
donsar's Avatar
donsar
Follow the manual - 55 or under for the first 500 miles with no jack rabbit starts and vary the speed. Don't keep it constant very long. Also for the sake of the brakes and tires keep the braking gentle if possible for the first few hundred miles.
It's going to be hard to keep that 400HP in check for the drive, but just sit back and enjoy the scenery,
Happy driving
Old Apr 29, 2005 | 10:43 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
1. Do what the manual says.
2. Follow the above advice. I believe they covered it all.
3. Ignore people who say to break it in hard.
4. Do what the manual says.
To Break In
