Air Bag Warning Lite
KICKBACK
Document ID# 1581169
2005 Chevrolet Corvette
2005 Chevrolet Corvette SIR Lamp After Horn Is Used: DTC B0104 , B0101 - kw air bag code indicator lamp light message MIL module restraint sensor #PIC3319 - (Jan 7, 2005)
2005 Chevrolet Corvette SIR Lamp After Horn Is Used DTC B0104, B0101
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in the PI.
Condition/Concern:
Some customers may experience a SIR lamp after depressing the horn for more than 5 seconds or using the horn two or three times in succession. A current or history code B0104 or B0101 may be set in the SDM.
Recommendation/Instructions:
Make sure that the horn bracket is properly attached and torqued to the skid bar asssembly of the frame. If the concern still exists, advise the customer that Engineering is Investigating the concern.
( NOTE: Replacing the SDM or the sensors will not resolve the concern.)
Please follow this diagnosis process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Models:
(05 Chevrolet Corvette)
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
KICKBACK
