Can someone please help me with the Paint code for DSOM, so that Í can give it to my painter. Need to do a little improvement on the hood lip! Tried the Search, but no luck!
When I had my door handles and brake light housing painted, the shop only needed the VIN to match the paint perfectly. The factory code is on the glove box door listing, but I don't know if that will help the painter. Hope that helps...
Mikael
Look in your glove box. You'll see a sticker in there. At the bottom of the sticker it says: "BC/CC U 633H" (at least that what it says in my DSOM).
That means that it is a Base Coat/Clear Coat system, and the paint code is 633H, which is a WA code that is something that your paint guy should be able to use (i.e., WA633H)
The GM paint code for DSOM is 71U, and that should be something your painter should be able to use as well.
