Need help
Old May 3, 2005 | 04:46 PM
dancmch's Avatar
dancmch
Default Need help
I just hit 2300 miles on the odometer and the check engine light has come on. I checked the gas cap and its on nice and tight. What could be the problem?
Old May 3, 2005 | 04:50 PM
WGHANDY's Avatar
WGHANDY
Cruising
Did you just get gas when you noticed the error indicator? That happened to me and i reseated the gas cap. It took some time, but the light went away after some driving.
I believe the car warns you when the gas cap isn't on correctly. I noticed when i shut my door after getting gas, the car will honk twice. I also see the service fuel system message displayed right after starting up after fill up.
If it wasn't during a gas fill up, then i'm not sure.
Old May 3, 2005 | 05:01 PM
Braced's Avatar
Braced
If you have OnStar, call them and they will tell you what the engine light is. One of the reasons I got OnStar.
ufso's Avatar
ufso
Dan,
Your first gremlin? Mine was the radio but it went away. Hope yours works out too!
See ya on the 15th at Kremes and then on to Hooters!!!
Sparky
Old May 3, 2005 | 08:00 PM
dancmch's Avatar
dancmch
Originally Posted by ufso
Dan,
Sparky
Hi Sparky, Missed you @ the last gathering. I even brought the wife. She might have to miss the meeting @ Hooters See you and the gang there!
Old May 3, 2005 | 08:04 PM
Trance Guru's Avatar
Trance Guru
Hmmmm....Krispy Kreme & Hooters.... what could be better than Donuts & wings....all of a sudden I'm hungry
Old May 3, 2005 | 11:12 PM
SDSC6LS2's Avatar
SDSC6LS2
It might be your Fuel Sender Card. There are a couple of other threads in regard to this problem. We are all waiting on the new cards to get to the dealers. Check out those threads.
Old May 3, 2005 | 11:14 PM
smdio's Avatar
smdio
OnStar.
eod
Old May 3, 2005 | 11:17 PM
Mocoso's Avatar
Mocoso
Yea could be the gas cap or the fuel sender or something else :-) - if ya have onstar have them diagnose it for you - if your fuel gauge is going nuts (goes to zero for a while then comes back) its the fuel sender card - owners manual stated driving it in this condition for extended periods of time could void warranty so if you cant get onstar to diagnose it have the local dealer do it for you
To Need help
