Paddle Shifter - Explain More
Old May 14, 2005 | 07:55 AM
Big Jimm's Avatar
Big Jimm
Default Paddle Shifter - Explain More
The new 6 speed auto coming (we think) sounds absolutely GREAT!
But, please explain more about what the Paddle Shifter does. I’ve owned a lot of new cars and trucks over the years but never knew much about a Paddle Shifter. I can only assume that it is the slider lever (one or two?) on the steering wheel that will let you force shift through the gears of an automatic.
Can you shift through ALL the gears with it or just up or down once for each gear like an overdrive switch?
The 2.53 rear axel is DOUBLY great for ME! I’ve always been a nut for as much an overdrive effect at cruise as possible. I realize that most of you young guys (under 60) probably are only interested in performance axels. But, for me, I like a low speed quiet engine at cruise. (This makes it easier to buy Borla Stingers, which I plan to get, since a lower engine speed means less cabin noise.)
The 2006 C6 is sounding better every day!! One could even say Yippee!
Old May 14, 2005 | 09:20 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
the july issue of 'popular hot rodding" has a story about a after market "paddle shifter" for 4 speed autos that should give you a good idea how it works
Old May 14, 2005 | 06:20 PM
Shylor's Avatar
Shylor
I believe the Mazda RX8 uses a paddle shifter with their auto, go test drive it.
Old May 14, 2005 | 10:00 PM
TRJ's Avatar
TRJ
Big Jim:
The 06 C6 will have a 6 speed Automatic Transmission with button shaped "paddles" attached to the back of the steering wheel. These button shaped paddles are in a position that will allow the driver to press them with his left or right thumb. One side will be for upshifting, the other for downshifting. You can place the normal shift lever in "D"
for drive and let it shift "automatically" or shift gears sequentially with your thumbs "manually." It hasn't been determined yet if the trans. will rev.match with a throttle blip, or just shift with whatever you have.
An Auto. Trans. with a Torque Conv. and the ability to shift gears sequentially with paddles. Almost like Play Station II.
Old May 14, 2005 | 10:12 PM
Frenchie's Avatar
Frenchie
Originally Posted by TRJ
Big Jim:
Negative. Both buttons, left and right, will be used to upshift (with either thumb). Downshifting will be done with either middle finger by pressing on the back of the wheel.
Old May 14, 2005 | 11:07 PM
TRJ's Avatar
TRJ
Frenchie,
The last sentance in your post (above), did you mean: by pressing on the back of the paddle? Rather than the "wheel?" In the pics that I have seen of the paddle attached to the wheel, it looked like the only piece in the attachment that would move was the button. You may be right, but all that I have read seemed to indicate that one side was for upshifting, and the other side for downshifting. I'm sure we'll all learn about it soon.
Old May 14, 2005 | 11:27 PM
rm50's Avatar
rm50
2020 C8 of the Year Finalist - Unmodified
The paddle shifter doesn't excite me if I have to give up any performance.
Old May 15, 2005 | 12:06 AM
Frenchie's Avatar
Frenchie
Frenchie,
There will be both "paddles" and buttons. The two paddles are located on the back of the horizontal bar of the wheel. You'll downshift by pressing on either one with either middle finger. The two "thumb buttons," facing front, are for upshifting. You'll notice that both have + on them.
Old May 15, 2005 | 12:18 AM
TRJ's Avatar
TRJ
I just magnified the photo showing a front on view of the paddles/buttons. You're right, there is a plus on both thumb buttons,
thanks for that info, Frenchie.
Old May 15, 2005 | 12:26 AM
Frenchie's Avatar
Frenchie
And I think that system will be better than the left-up, right-down (or vice versa) system. More flexible and easier to acquire the "reflex." But I have to agree with those who see this as mostly gimmickry. The real news, the GREAT news is the A6. I wish the paddle/button shifter were an option so that I could not get it, but it'll be standard with the A6. Oh well, might be fun...
Old May 30, 2005 | 12:08 PM
RedHot's Avatar
RedHot
CI 5-6-7-8-9-10 Vet
I drove an '06 Vert with paddle shift at Bowling Green on Saturday. You can leave the trany in what ever gear you happen to be in when you come to a stop and it will downshift for you (to 2nd) if you foreget.
Old May 30, 2005 | 01:39 PM
RJMan's Avatar
RJMan
My wife's Toyota Celica GTS has the paddle/button shifters on the steering wheel. Very intuitive - push down for downshift and pull up for upshift. Makes good sense and after you use it for a little while, you don't have to think about it.
When I drive her car, I never use the Auto position, always put it in manual. In addition, there is an indicator on the speedometer that indicates what gear you have selected. It's great in stop and go traffic and prevents the tranny from constantly shifting up and down.
It would initially appear that some nut at GM has the new A6 set up backwards (push down for upshift & pull up for downshift). I think that alone will take some getting used to. Just my .02 worth.
Old May 30, 2005 | 03:33 PM
ProfMoriarty's Avatar
ProfMoriarty
Since you typically downshift into curves, it makes more sense to have your thumbs wrapped around the wheel and downshift with a fingertip behind the wheel like the A6 set-up.
Old May 30, 2005 | 04:27 PM
webdzynes's Avatar
webdzynes
How quickly did it engage? If I'm hammerring it, I want it to react "instantly" - if that's even possible...
Old May 30, 2005 | 04:34 PM
Sportsdude's Avatar
Sportsdude
This is what it looks like in my BMW
Old May 30, 2005 | 05:10 PM
Curtis A. Franz's Avatar
Curtis A. Franz
Your comments seem to suggest tht the A6 will normally start off in second gear. That is an old Ford trick.
Old May 30, 2005 | 05:18 PM
double eagle's Avatar
double eagle
That's what BMW's Steptronic does, but you can manually downshift to 1st when stopped.
To Paddle Shifter - Explain More
Old May 30, 2005 | 08:00 PM
GTC's Avatar
GTC
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
It reacts very quickly. I was able to ride shotgun in it on Saturday. I still like my A4 with 3.15.
Old May 30, 2005 | 08:17 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
what photo ??
Old May 30, 2005 | 09:01 PM
ProfMoriarty
So, let's hear about the ride you took!
Z51? Std suspension?
etc...!
