radio static
Old May 15, 2005 | 08:26 AM
Top Flight Reproductions's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15
Default radio static
Does anyone know if GM has a fix for the Radio static problem? Changing back and fourth between AM and FM is becoming a pain in the ***.
Old May 15, 2005 | 09:04 AM
GaryTX's Avatar
GaryTX
I don't seem to have that problem. Mine is only with XM. They will fix it if enough people post they are having the same problem.
Old May 15, 2005 | 09:44 AM
hlcptr's Avatar
hlcptr
Look at this thread in the C6 FAQ section:
http://forums.corvetteforum.com/showthread.php?t=945546
Old May 15, 2005 | 08:15 PM
C6-er's Avatar
C6-er
From: Just another gray haired old fart in a Corvette.
From Ken's newsletter.
4) Poor and/or No Radio Reception, Intermittent Static on FM with Navigational Radio System
Models: 2005 Chevrolet Corvette with Navigational Radio
Condition
Some customers may comment on intermittent static on the FM band, poor and/or no radio reception when they turn on the radio.
Cause
A radio calibration may be the cause.
Correction
DO THIS:
Test the radio in its static condition by switching from FM to AM and back to FM. This should clear the static on the FM band.
DON’T DO THIS:
DO NOT attempt t make repairs at this time if switching from FM to AM and back FM clears the radio static. DO NOT replace part numbers: 15233090 or 10321830.
Test the radio if/when the static/poor reception condition occurs or explain to the customer to test the radio if/when the static condition occurs.
1. While the radio is experiencing static on FM, switch the radio from FM to AM and then back to FM.
• If the static does NOT clear when returned from AM to FM, refer to Radio Poor Reception (SI Document ID# 1556108).
• If the static clears when returned to FM, NO further repairs are available at this time.
2. Engineering is currently working on a calibration fix. NO repair attempts should be made at this time.
Dealer Action
• Record the customer information on a permanent record so you may contact the customer when a repair becomes available.
• Advise the customer that a repair is in test and validation and is due out soon. At the time the fix becomes available, it will be the dealer's responsibility to contact the customer.
Old May 15, 2005 | 08:24 PM
LS WON's Avatar
LS WON
Default So in other words just wait till they come out with a fix?
Condition
Cause
Correction
DO THIS:
DON’T DO THIS:
Dealer Action
Old May 15, 2005 | 08:26 PM
LS WON's Avatar
LS WON
Default I don't have navagation and I still get static and loose stations on FM. Switching
from AM-FM switch doesn't really seem to help. Do aftermarket stereos have the traffic feature and identification of stations, songs and the emergency alert feature broadcast if not more features than the factory system.?
To radio static
