cargo cover problem
Old May 15, 2005 | 05:15 PM
aaflame33's Avatar
aaflame33
Default cargo cover problem
undefined
I had the roof off on the Coupe today and took a wonderful ride up along the Ocean. (Atlantic) It was dream like except for the flapping
of the cargo covers front flap that kept waving in the rear view mirror.
Very annoying.
Anyone come up with a solution?
Old May 15, 2005 | 05:20 PM
Tropical'67's Avatar
Tropical'67
Someone here mentioned before that they inserted a rod of some type in the leading seam of the cover. I might try that too with a fiberglass rod. Should be enough weight and taut enough to keep the cover from flapping.
Old May 15, 2005 | 05:21 PM
BIGGGIE's Avatar
BIGGGIE
St. Jude Donor '05-'06-'07-'08
Go to Home Depot and buy a lead rod and have it cut to size...and the slide it threw the hole on the end of the flap...Dont know what thickness to buy ..But something the thickness of a pencil or maybe a little thiner...
Old May 15, 2005 | 05:34 PM
aaflame33's Avatar
aaflame33
Default cargo cover
Originally Posted by aaflame33
undefined
Very annoying.
Thank you very much gentleman, I didn't even notice the sleeve in
the cover, Home Depot here I come.
thanks again.
Old May 15, 2005 | 06:36 PM
S22C6's Avatar
S22C6
I too read that somebody had put a rod in the seam of the cargo cover but found it too inflexible.
He ended up buying a length of clear plastic hose that would fit the seam and filled it with BBs or lead shot. This way you get the weight but retain some flexibility.
Old May 15, 2005 | 06:39 PM
Another Yellow's Avatar
Another Yellow
St. Jude '03-'04-'05-'06
That's the way to go.
Old May 15, 2005 | 08:10 PM
aaflame33's Avatar
aaflame33
Thank you S22c6, I'm glad I didn't buy the rod yet.
Thanks one and all.
Old May 15, 2005 | 08:17 PM
NextOne's Avatar
NextOne
...and then he took a heat gun to "shrink rap" the beads. This sounds like a mod for someone to market. My biggest annoynace when driving with the top out is having to buckle the passenger side seatbelt to keep it from vibrating in the wind.
Old May 15, 2005 | 08:21 PM
LS WON's Avatar
LS WON
Default My cargo cover and cargo net are both still in the plastic bags
Gotta find time to put them in hope it's easy and doesn't take much time otherwise I loose forum time on here.
Old May 15, 2005 | 08:30 PM
stanleyp's Avatar
stanleyp
Way too complicated.
Take the cover off.
Old May 15, 2005 | 08:36 PM
Rogue C6's Avatar
Rogue C6
Three safety pins secure the flap back to the rest of the cover.
Patrick
Old May 15, 2005 | 08:47 PM
GGWOODY's Avatar
GGWOODY
From: Buena Park, CA I seem to have left my electrolytes with your daughter
Patrick
Now that makes cheap, easy, sense...the other thing though, Can't remember his handle but guy driving silver coupe w/ "BLZNVET" plate said that keeping the cargo cover in place with the top mounted in the cargo area causes an issue. He showed me on my clear top where the taught elastic band, that traverses the cargo area, at the front beats againt the top, and wears a nice straight line accross it. Keep this in mind and just take off the cargo cover when you put your top in the back.
Thanks BLZNVET
Old May 15, 2005 | 08:57 PM
dollarbill's Avatar
dollarbill
St. Jude Donor '06-'07-'08-'09-'10-'11
Tint the rear window with 30% and don't use the cargo cover. Nothing to flap. You can still see out just fine.
Bill
Old May 15, 2005 | 10:37 PM
hamshog's Avatar
hamshog
I am the one that posted using the steel rod. It works great. Windows down and top off. The rod is 3' X 3/8 thick. It holds the curtain in place. Someone was worried about scratching the top but it hangs below the top no porblem. If you have any concerns it is easy to slip out. Using bb's in shrink tube would be hard to slide in and out of the hole. I bought my steel rod at Lowe's. I am sure Home Depot will have the same. Cost $4.75.
Old May 15, 2005 | 10:51 PM
black783's Avatar
black783
Like the rod idea....How the heck did GM miss this? They must have run the car without the top off
Old May 15, 2005 | 11:59 PM
aaflame33's Avatar
aaflame33
Default cargo cover
Let's see now.
Fiberglass rod
Steel rod
Tubing with BB's
Take it off
Tint back window
Safety pins
You guys all have such great ideas, I'm so confused.
Thanks again
Old May 16, 2005 | 07:03 AM
Corvette Junkie's Avatar
Corvette Junkie
Night Race Blue 427
From: Muncie, Indiana ...... Can I buy an amplifier on time ... I ani't got no money now but I'll pay you before I die
All of this almost makes me wish that I would have bought a coupe instead of a vert.
Old May 16, 2005 | 08:58 AM
TRAIL BOSS's Avatar
TRAIL BOSS
Agree!
Old May 16, 2005 | 03:50 PM
Pat W's Avatar
Pat W
I was the one who used bb's in heat shrink tubing and it still is working fine. However in that post, another gentleman had what I think is a better solution. He used small fishing weights on some fishing line. It would be a more flexible, heavier and cheaper solution than mine.
To cargo cover problem
