Colgan Bra Issue/Question
My concern is the way it mounts at the top of the wheel well on each side. Mine does not seem to want to stay hooked around the lip very well. See the pictures below. Is there some trick to this, like squeeze it in behind the wheel well liner like the lower two. The instructions are not very clear on this.
Plus the instructions do not address the hooks that are inside the hood except for the two outer ones or some of the hooks that are around the lower opening. I could figure out that they needed to be hooked up, but the instructions address each of the other hooks with pictures, then totally ignores about 6 others.
While I am on the subject of instructions, they are copied with a black and white copier that does not have much resolution. The pictures are somewhat fuzzy. I guess I would expect a little larger color photo as well as addressing ALL the hooks. This would provide a more complete guide that leaves nothing to guess.
Well anyway, here are the photos that show my concern. The top of the wheel well is where I would expect issues.
And now the close up on the drivers side.
So is this just the way it is?
Thanks..
Jim
I disagree, on the Boxster I found that you should adjust the tabs (yes, bend them) to get a better fit. I would play with it until it looks OK to you, just make sure it is done in the heat of the sun so that you get the maximum of flexability and tightness.
On the Boxster, the Colgan bra looks great and it is a great protector of the front end. I really like this product. If you are going to use a bra (many will not use one under any circumstances) this is the best way to go. The Colgan colored match bra is the best deal for the money. Speed Lingere is good but much more $$$.
Thanks..
They are nearby, so I went to their facility to see how well the MY color match was.
They wanted pictures of a MY installed, so they mounted it for the photo shoot.
These are pics I took a day or 2 later. Sorry, no real close-ups.
what a great color match.
I'm also very happy with the color match on my Speed Lingerie, but I got burned for WAY too much money for it. Had I known about Colgan at the time, I would have gotten Colgan instead. Your fit looks better than mine also.
BTW, I did get mirror covers from colgan - perfect color match -- for $69 -- I was pretty happy with that price.
Also, Bras are going to have to be cleaned. Probably the best way is while it is still on the car, then take it off so it will dry. I figure the black will be easier to keep clean too.
I doubt the Speed Bra is worth the extra $$$ in terms of protection but I do like the way it mounts as compared to the Colgan, but long term will tell.
