1sa - Adding heated seats?
Old May 21, 2005 | 07:43 PM
scot's Avatar
scot
Default 1sa - Adding heated seats?
Has anyone added heated seats to a 1sa? Is it already wired up, but no switches to control the heat? Many cars are configured like this due to the extremely low cost of the elements, but high cost of multiple configurations. No idea if the c6 is setup like that or not.
Scot
Old May 21, 2005 | 08:00 PM
Vette_DD's Avatar
Vette_DD
You can't get GM to add the heated seats without paying for the 1SB option. I guess you're asking if anyone has tried to see if they are pre-wired in the 1SA, just waiting for a DIY person to make the circuit hot. Have not read any threads here where someone tried it.
Old May 21, 2005 | 10:06 PM
cerino2000's Avatar
cerino2000
I would imagine they are pre-wired. I am trying to find out the same thing about the memory seats. Is it a matter of having the door console buttons?
Old May 21, 2005 | 10:53 PM
ProfMoriarty's Avatar
ProfMoriarty
An extra hot option is available for those male drivers who do not wish to father children.
Old May 21, 2005 | 11:49 PM
Force-1's Avatar
Force-1
St. Jude Donor '08 thru '24
I believe in the Beer Fairy
USAF (Retired) 1979-2001
There are many upholstery shops that can add heated seats to any car.
Old May 21, 2005 | 11:54 PM
scot's Avatar
scot
PM: Im not out to have any children, but I don't think thats quite the way I want to "make sure".
As for the seat memory, I bet it is two fold. Probably one of the cpus needs to be told to do it through the standard dealer corvette computer tool as it is most likely turned off, and the switches need to be added in. For heated seats the controls are built into the heaters as any other way could potentially lead to the professors stated suggestion. The switches just supply the relay voltage to the heating circuits which control the output themselves. (at least thats the way it normally works)
One way or another I will be attempting to DIY it, so if no one else has tried it I guess I will be the guinnea pig.
Scot
Old May 22, 2005 | 07:32 AM
Pipedreams's Avatar
Pipedreams
St. Jude Donor '06-'07
We should check with parts to see if they list only one seat or two. Also I have a 1sa build sheet and I will check if it has the seat code, if someone has a 1sb build sheet can you list what yours says
Old May 22, 2005 | 08:57 AM
scot's Avatar
scot
Good idea, I'll check at the next corvette club meeting. Someone there will have to have a new c6 with 1sb. Might also try to see if I could check at the dealer when I pick my car up, but then again will probably be so excited that checking build sheets will be really really far back in my mind. I got my fingers crossed that they are the same and its just a simple wiring matter!
Also, does anyone happen to have a wiring/electrical manual? That would also be useful to try to track down how the seats are wired up. One worry I have is that the seats are wired, but the car is not. Could be something as simple as just tapping available sources, but probably will mean wiring back into the fuse box and getting some connectors or maybe an update to the computer. Course on the land rovers (depending on year) you just need to buy 2 10 dollar switches and a 30 dollar plate and you are good to go. Maybe this will be that simple.
Scot
Old May 22, 2005 | 09:12 AM
Another Yellow's Avatar
Another Yellow
St. Jude '03-'04-'05-'06
Build sheet for my 1SB shows the RPO as AQ9 SPORT SEAT It also has RPO code KA1 HTD SEAT
What does your build sheet say?
Frank
Old May 22, 2005 | 01:51 PM
Low12s's Avatar
Low12s
From: Life isn't about waiting for the Storm to pass, it's about learning to dance in the Rain.
lol
Old Nov 23, 2011 | 10:28 PM
Wsawyer's Avatar
Wsawyer
1st Gear
I'm trying to add seat heaters also. The dealer is saying that in order for the heater controllers to work, the computer needs to be reprogrammed to enable the controllers. They are quoting $1500 for both seats and they really don't want to do the job. Let me know if you are successful in getting them working. Wsawyer@nc.rr.com
Old Nov 23, 2011 | 11:35 PM
mpuzach's Avatar
mpuzach
Do you realize that you just posted in a thread that died 6 1/2 years ago?
Old Nov 24, 2011 | 01:05 AM
CO Lightfoot's Avatar
CO Lightfoot
Heck, for $20 you could get a simple heating pad:
http://www.amazon.com/Wagan-IN9738-5...2113749&sr=1-1
Just be sure to unplug/turn it off after use, or you might kill your battery.
Or you could install an aftermarket integral heater, like this:
http://www.amazon.com/Dorman-628-040...2113086&sr=1-2
I bet any decent auto upholstery shop could install a heater kit.
As long as the seat is disassembled, replace the seat bottom foam:
http://forums.corvetteforum.com/c6-c...9-shipped.html
Or, at the very least, use this rebuild kit:
http://forums.corvetteforum.com/c6-c...-kits-jwm.html
I installed the rebuild kit on my 09... protects the foam and big improvement in support, eliminated my back discomfort on long drives.
And here's a MUCH more recent thread on seat heaters:
http://forums.corvetteforum.com/c6-c...ted-seats.html
To 1sa - Adding heated seats?
