Telescoping Steering wheel malfunction
Old May 22, 2005 | 01:32 AM
jimman's Avatar
jimman
Default Telescoping Steering wheel malfunction
Anyone have this problem, no movement with control or memory?
Old May 22, 2005 | 11:20 AM
coolcat's Avatar
coolcat
This is one option on my C6 that I never use. I just leave it in the postion closest to the dash.
Old May 22, 2005 | 11:38 AM
KISSfn's Avatar
KISSfn
My dealer had to order a new switch and I'm having it replaced next week.
Old May 22, 2005 | 01:37 PM
jimman's Avatar
jimman
Did the memory recall still work?
Old May 22, 2005 | 01:40 PM
KISSfn's Avatar
KISSfn
Nope.
Old May 22, 2005 | 01:43 PM
Hoonose's Avatar
Hoonose
Maybe a fuse or wire. Check the manual for fuse # and location. Sounds like it may be a trip to the dealer....
Old May 22, 2005 | 01:44 PM
shopdog's Avatar
shopdog
Nope.
Then it probably isn't the switch. The switch is only used for manually moving the wheel. More likely it is a motor or wiring fault, and your dealer is chasing the wrong problem.
Old May 22, 2005 | 01:56 PM
KISSfn's Avatar
KISSfn
A Chevy dealer that doesn't know the C6 inside and out? Can't be.
Old May 26, 2005 | 09:24 PM
jimman's Avatar
jimman
took it to dealer Monday and picked it up on Wed when I returned from busness trip. System worked fine and they could find nothing wrong. I did a final try before I left it and it was totally dead. Damned if I know what went wrong but it works fine now.
To Telescoping Steering wheel malfunction
