Another Garage Floor
Before we selected the "best" garage floor tile for our needs, a comparison of the two leading floor tiles was made. Mock-up/testing were conducted for durability, ease of installation, design/selection and cost. Here are our reasons for the selection of Lock-tile product:
1. Material: a green-product consisting of recycled PVC. It was more pliable, not as hard to cut and can be laid in any direction. The tile is only a ¼” thick and that helps minimize problems from under cutting doors or other obstacles. We found the Lock-tile softer and were easier on the ear for sound attenuation.
2. Installation: Lock-tile comes in 19 5/8" squares which minimizes joints. A major plus over other tiles was that the tile could be laid and connected in ANY direction meaning you didn’t have to lay the tile in a specific direction. Additionally, you could cut any side and not worry about a hook or loop would not line up.
3. Cost: Both products are "expensive" compared to paint systems and costs about $2.75-$3.25 a square foot. So the price, if you plan spend this much anyway, was NOT a determining factor.
4. Design/Selection: Lock-tile does not offer as many “stock-standard” colors. We also noted that some of the four-way intersecting locking joints were not as tight, square fitting. The larger tile does limit patterns/designs but the lack of joints is a trade off.
5. Durability: Both products exhibited exceptional resiliency, and clean up capability. One aspect of the Lock-tile we liked was that it didn’t “scratch” as easy.
This is my opinion and review of why we selected Lock-tile. Please note that this is an unbiased review and no affiliations with any aforementioned parties..Thanks.
This looks like the flooring that I will be using for my shop. I like the fact that you can lay them from wall to wall.
Are Lock-tile beveled edge tile strips available? Do they attach with dovetail joints as well?
If you don't mind me asking where did you purchase your tiles from?
Thanks,
John
It will be a few weeks before I lay the floor. I am having a heatpump unit and insulated ceiling installed.
John
By the way thats a beautiful floor you have.
John
The Race Deck/Crafstman system is polypropylene which is flexible, but will expand under direct sunlight, consequently while a joint as tight as the masonry at Machu Picchu looks great and is more dust resistant than a joint that allows a slightly looser fit, it does not allow for expansion and can result in some lifting with polypropylene.
Your garage floor looks awesome!!! Thank you for sharing the pictures and your review with us
I sent in a request to Lock-Tile for a free sample and their literature.
I have a question: Did you apply anything on top of the tile to make it look so shiny? Looking at the pictures, it doesn't appear to be that shiny during the installation.
Almost complete
