Not-so-automatic latch
Old May 31, 2005 | 11:34 AM
rudybeet's Avatar
rudybeet
Default Not-so-automatic latch
Supposedly the coupe hatch should latch automatically once it starts to pull itself down. I find I have to pull it down with at least some force for this to happen. Is this normal?
Old May 31, 2005 | 11:40 AM
stanleyp's Avatar
stanleyp
Absolutely.
It wasn't intended to be like the Caddy's auto pull-down.
Just give a good pull on the handle to get the momentum going and then the mechanism does the rest.
Old May 31, 2005 | 11:56 AM
footba4672's Avatar
footba4672
mine is the same way....think its normal
Old May 31, 2005 | 12:07 PM
Another Yellow's Avatar
Another Yellow
St. Jude '03-'04-'05-'06
That's the normal way.
Old May 31, 2005 | 12:11 PM
bbster's Avatar
bbster
Default Latch
It is normal......
Old May 31, 2005 | 12:12 PM
lehew's Avatar
lehew
That's normal. If you close it gently, it doesn't catch. If you close it hard, it closes immediately. Somewhere in between and it will catch and pull down the rest of the way.
Old May 31, 2005 | 12:31 PM
StanNH's Avatar
StanNH
If your windows and doors are closed, it will take some force to enage the electric pull down. There is a grab handle under the hatch that makes it easier to flip the hatch lid down.
If a window or door is open, the hatch lid will drop and close easily.
Old May 31, 2005 | 01:40 PM
Pat W's Avatar
Pat W
I'm to the point now that I make sure there's a window or door open before dropping it down. It's easier than removing the hand prints off the lid when you push hard.
Old May 31, 2005 | 07:36 PM
2bubbas's Avatar
2bubbas
Just takes practice to get just the right amount of force.
Old May 31, 2005 | 09:03 PM
Datawiz's Avatar
Datawiz
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05 thru '11,'19,'22,'25
St. Jude/CI Name Tag Designer
Mine acts the same way. I heard from one member who was invited to the, for the lack of a better phrase, the "warranty get together" for owners and GM put a new style latch on that worked much better. GM is aware of the problem, but I guess we all have to just deal with it. It is very inconsistent at best.
Old May 31, 2005 | 09:32 PM
19stingray70's Avatar
19stingray70
When I pull my handle down with force it feels like it is about to snap in half
Old May 31, 2005 | 10:08 PM
crazyeddie's Avatar
crazyeddie
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
To Not-so-automatic latch
