I have the C6 Vert and have been having intermittent issues with the XM. Yes the sound quality isn't that good, but lately it seems to cut out quite frequently as well. Does anyone else have that or is there something wrong with it. It cuts out while driving in the open and sometimes for many seconds.
My XM unit cuts out repeatedly on the same roads in the same locations in the Pittsburgh area. There has to be something blocking the signal.
A few days ago there was a thread about intermittent XM reception, and it appears it may not be a subscription or an antenna problem. Most of the people who posted to the thread, including me, have reception about 20-30% of the time, with long, lonely patches of silence. There are theories, but one person thought it might require a reflash. It seems like an antenna problem, but those who had their antenna replaced had the same problem afterwards.
I predict this will be as popular a topic as the faulty fuel sensors and sending units in the C5...
I'm very disappointed in reception of XM. Since it goes away in the same place every time I assume that something (power lines or ??) are blocking signal. Works great in a short tunnel that I go through however. I'm seriously considering not renewing because of reception issues. Also volume is much lower than FM which should be fixed in radio.
I'm really surprised this isn't a big issue in the press etc. Good coast to coast but only if you like intermittent sound.
I haven't had issues...well I did have a couple drops in a very steep and deep canyon but that's expected as I lost the line of sight to the satellite. Are you going thru deep forest when it happens?
Maybe you folks could list city/state of the dropouts to see if there's any correlation.
Out in So Cal (Santa Clarita, San Fernando Valley, Simi Valley, El Segundo, and Santa Barbara) I find dropouts non-existent. I have it in 2 vehicles.
I have the same problems also (coupe).....hear it's software related....I will not renew until the problem is found....by the way, XM works perfectly in my other vehicle (Acura).
I have a convertible and it drops everywhere. It didn't happen at all for the first day I used it then it progressively got worse the next day. I can be in an absolutely clear road with no trees or anything and I loose reception.
My XM reception drops only in one location that I know of. Every morning I drive under this one underpass I lose reception for about 2 seconds. No where else.
I'm having issues with XM also. Drops out quite a bit. I realize going around buildings and under bridges will cause it to drop but I'm losing it out in the open now. Had the car since mid March and the XM reception is getting worse.
On a side note - I called and renewed my subscription for the $60.00 deal for a year back in April when I heard about it. They confirmed it over the phone and said they would charge my credit card when my three months expired. It's close to the end of three months and I just got a renewal form in the mail - for the full price! I'm waiting to see if there's a mix up and they charge my card the $60.00. I won't pay the full price.
Rick
Even under bridges and around buildings it should not drop. I have XM in three of my vehicles, and have had it in two others. My Acura never loses reception - even in downtown Houston. Our Tahoe never loses it either. Corvette is too new to tell, but I hope this is not a problem in mine - I'd hate to think I have that wart on my *** for nothing!
I have a coupe, VIN 19944. I have only had XM drop out near tall buildings or if I'm close to a rock wall on the south side. Otherwise, the reception is clear and sounds better than FM. I also have not noticed any volume differences between sources.
On a separate issue, my XM cuts in and out on the right channel. Pressing around the Nav screen brings it back in for a moment. I believe something must be loose back there, although I'm surprised it doesn't do it on AM, FM, or CD. It is going into the shop for this issue tomorrow.
6/6/05 - For the record, cause was a pinched wire behind the consol. Fixed now and it sounds great!
Reason: New Info
I have a suggestion that might not solve your problem but it's free and easy to do so what the heck. Sometimes the XM radio needs to be "refreshed" with new decoding information. the XM site has an on-line utility to allow you to do this (can also be done with a phone call to XM). Here is the link for the XM Refresh. Also, last I looked into it, there are two XM satellites in service now and a third was launched a few months ago. I don't think the third is on-line yet so coverage might improve in you area in the very near future. A good site for all the information you would ever want to know about XM is XM411.COM. One last tidbit: there is an XM antenna pointing utility HERE that, while worthless for a car, will give you the azmuth and elevation of the satellites you're trying to recieve, giving a rought idea of which obsticles (mountains, buildings, trees) are likely to block the satellite view. If you live or traveling in an area where the satellites are at (relatively) low angles you're likely to have more dropouts
