Physics Question
Old Jun 2, 2005 | 08:21 PM
b4i4getit's Avatar
b4i4getit
Default Physics Question
My Mechanical Engineer friend says that since I rarely have a passenger in my car that I really should overinflate the drivers side tires a few pounds. His rationale is that the drivers weight would be unevenly distributed to the left front and rear tires and if they are overinflated a bit the tire wear would be equalized on both sides. Is he right ?
Old Jun 2, 2005 | 08:22 PM
ProfMoriarty's Avatar
ProfMoriarty
I thought this thread was going to be about Milk of Magnesia.
Old Jun 2, 2005 | 08:43 PM
flyzlow's Avatar
flyzlow
No need to worry about that because the torque of the engine under acceleration tends to pull the engine to the right or passenger side so it causes the car to lean that direction offsetting the weight of the driver. You can also add a 150 lbs. of weight to the passenger seat. I know, I'm a real racer!
Old Jun 3, 2005 | 12:55 AM
C7 BOB's Avatar
C7 BOB
I usually put one pound more on the left side vs. the right, and one pound more on the front vs. the rear, when there's no passenger or luggage. Probably not significant, but I think it's logical.
Old Jun 3, 2005 | 01:07 AM
rm50's Avatar
rm50
2020 C8 of the Year Finalist - Unmodified
Check his car and see if pratices what he preaches.
Old Jun 3, 2005 | 01:20 AM
74_LS-4's Avatar
74_LS-4
Several things here.
1. If you look at the percentage weight difference that we're talking about it's not a few pounds, it's only about a pound or so (unless you weight 300 lbs). And who's to say that the left-right balance of the car is perfect to begin with?
2. Now, let's assume one side is slightly heavier. Does that necessarily mean more psi in the tire? What about front-rear differences in weight? Given the same tire size and construction, if a car is 60/40 split front to rear do you always put more air in the front to compensate?
Old Jun 3, 2005 | 01:26 AM
shopdog's Avatar
shopdog
That's one way to do it, but uneven inflation means you'll get an uneven footprint on the ground, and that's bad.
My car came from the factory with the ride height staggered, unfortunately the wrong way, ie it was lower on the passenger side than the driver's side with driver on board. So I adjusted the ride height screws so the car was level side to side with the driver on board. NASCAR mechanics call this wedge, and what I did was set the car up so that with the driver on board there was zero wedge.
A more sophisticated way to do this is to set the car up on scales so that the weight is the same side to side on the wheels. But setting the ride height level when the car is loaded the way it will be driven is almost as good, because the car's springs act like a spring scale, and only requires a ruler.
Old Jun 3, 2005 | 01:30 AM
jericho573's Avatar
jericho573
How heavy of an acceleration might one need to have that pulling to the right?
Old Jun 3, 2005 | 10:28 AM
MitchAlsup's Avatar
MitchAlsup
No, if you want to get this picky about your suspension setup, you need a set of scales and cornerweight the car. But even if adding a little pressure to the drivers side of the car were the right thing to do, the order of magnitude of pressure increase will be a lot closer to 0.1-0.25 PSI rather than 1 PSI or greater.
The statics of the issue is that the center of gravity of the driver is fairly close to the centerline of the car and the tires are close to the outside of the car. Thereby even if you weighted in at 300 pounds, you wuld only have about a 100 pound disadvantage on the drivers side compared to the passenger side.
Old Jun 3, 2005 | 11:10 AM
mark b's Avatar
mark b
They should make all sports cars and Vettes with the drivers seat in the middle(ala Mcclaren) wouldnt that be wicked! Gm are you listening?
To Physics Question
