Is LoJack Causing DBS?
Old Jun 15, 2005 | 02:33 PM
prs62's Avatar
prs62
St. Jude Donor '05-'07
Default Is LoJack Causing DBS?
I saw this posted on GM TechLink. It implies that aftermarket security systems like LoJack may be the cause of dead battery syndrome. For those who have experienced DBS, do you also have Lojack installed?
Low or Completely Discharged Battery:
Owners of some 2004-05 Cadillac XLRs and 2005 Chevrolet Corvettes may comment that the battery has a low charge or is completely discharged at times.
If a cause can not be located with normal diagnosis, check with the customer or the sales department to determine if the vehicle is equipped with an aftermarket security system. These systems use a small transmitter or GPS locator that is hidden in the vehicle and is usually unknown to the technician. The transmitter is typically installed in the hot-at-all-times dome lamp circuit and prevents the Body Control Module (BCM) from entering the sleep mode.
- Thanks to Paul Radzwilowicz
Old Jun 15, 2005 | 03:21 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
No Lo-Jack or any other add-ons and I've had several DBS incidents. Still searching for the answer.
Old Jun 15, 2005 | 03:31 PM
PJinNJ's Avatar
PJinNJ
Default Nope
No lowjack or any other thing. It'll take more that shots in the dark to resolve this DBS issue.
Old Jun 15, 2005 | 05:39 PM
prs62's Avatar
prs62
Sorry guys. I was hoping the general was onto something to solve the problem.
Old Jun 15, 2005 | 05:48 PM
StanNH's Avatar
StanNH
What makes this so tough is that only some cars are being affected by it. My car sat in an unheated, ice cold garage all winter. I started it every 7-10 days...it always turned over instantly and the battery has been fine. That's with temps as low as -30F! Others have had their batteries go dead in warm climates or heated garages for no apparent reason.
I don't have NAV, XM, or OnStar. I wonder if there's a common thread concerning a certain factory accessory that's in the car. Are cars without OnStar going dead? There has to be something in these cars that preventing a complete electronic shutdown. It's obviously intermittent or the dealers would be able to see it. Maybe an interaction with a garage door opener set on a certain frequency?
This whole issue is very weird and very frustrating.
Old Jun 15, 2005 | 07:51 PM
sallen619's Avatar
sallen619
LO-JACK should not be causing the problem. It runs on it's on battery power. I've had my car since november and it hasn't happened to me yet...
To Is LoJack Causing DBS?
