C6 break in question???
Old Jun 16, 2005 | 08:20 PM
adamsmb's Avatar
adamsmb
5th Gear
Default C6 break in question???
I am so excited. Just got news that my c6 (machine silver/ebony) mn6 1sb f55 has been built and will be delivered next week. I need forum members input on the break in. I have read on several threads that the car should be "babied" during the 500 mile break in. My sales person is telling me that it should not be "babied" but run just how I intend to drive the car long term. In other words, push it hard from day 1. I need some advice. I want to break this car in with the intent to give it the best long term performance. I know rpm's need to be varied during break -in.... but should I really push the car to the limits even during the first 500 miles? PLease weigh in on this issue.
Old Jun 16, 2005 | 08:25 PM
sallen619's Avatar
sallen619
Break it in according to the manual. The engine, transmission, rear diff and brakes need to broken properly to insure good long term use....IMHO.
Old Jun 16, 2005 | 08:26 PM
C6Harley's Avatar
C6Harley
Rule #1 SALESMAN ARE MORONS
dont drive the car like a bat out of hell. Give the moving parts a chance to wear in. Vary speeds and RPMs, but dont start redlining it and slamming through gears for at least 500 miles
Old Jun 16, 2005 | 08:29 PM
paralizer's Avatar
paralizer
Of really big importance is no hard braking, unless absolutely needed, the first 200 miles.
Paralizer (newbies first post)
Old Jun 16, 2005 | 08:38 PM
erosinski3882's Avatar
erosinski3882
Drive it like you stole it.
Old Jun 16, 2005 | 09:23 PM
Braced's Avatar
Braced
I always drive my stolen cars as if they were my own!
Old Jun 16, 2005 | 09:27 PM
Zoltan's Avatar
Zoltan
I drove easy for 500-700 miles. Then drove faster. Now at 2700 I drive it like I stole it and have no problems.
Old Jun 16, 2005 | 09:37 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
Ignore people who tell you to drive the hell out of it ( not to be confused with AFTER 500 miles - then I drive the hell out of it). Follow the owners manual.
vary the engine speed
try to keep your speed down (for the ring and pinion)
no hard accelleration (to allow the ring and pinion gear faces to wear in before you load them)
easy on the brakes
Old Jun 16, 2005 | 09:44 PM
Corvette400400's Avatar
Corvette400400
From: Horsepower is how fast you hit a wall, torque is how much of the wall you take with you Jacksonville, Florida
St. Jude Donor '05
Just do what the little manual tells you to do and it will be with everything not just break in. I can not even begin to tell you how important the manual is, there is so much stuff in this car, ie. electronics, gizmos, gadgets, controls, indicators, etc. that this thing is like a freakin airplane! Having a handle on the manual is essential because there is so much technology to enjoy in this car that knowing how to use it will eventually come in very handy.
Old Jun 19, 2005 | 06:17 AM
gota07's Avatar
gota07
Cruise-In VIII Veteran
The manual states 55mph max. Would doing 65-70 to keep up to interstate speed make much difference? I would feel like a slow poke going 50-55 on the interstate on the drive back home from NCM. Should I plan to take a senic route instead of the interstate?
Old Jun 19, 2005 | 06:56 AM
hugeforlife's Avatar
hugeforlife
as you're driving down the freeway and the odometer rolls to 501 make sure you downshift to second and bury your right foot to the floorboard.
Old Jun 19, 2005 | 07:37 AM
V Vette's Avatar
V Vette
just dont slam on the brakes!!!
Old Jun 19, 2005 | 08:32 AM
Corvette Junkie's Avatar
Corvette Junkie
Night Race Blue 427
From: Muncie, Indiana ...... Can I buy an amplifier on time ... I ani't got no money now but I'll pay you before I die
Doing 65-70 on an interstate won't hurt. But I would take the small highways for the first few 100 miles though.
Old Jun 19, 2005 | 04:07 PM
INTRUDR's Avatar
INTRUDR
I picked up my coupe at the NCM last month. I put about 150 miles on it initially driving through the backroads of Kentucky using my Garmin GPS unit, which was very helpful in navigating unknown roads. I had pre-programmed a route which would ensure relatively slow (less than 60 mph) speeds with numerous starts, stops, curves, and the need for frequent gear changes. After that, it was mostly Interstate roads back to Houston. I did vary the speed (55 and above) and the gears (mostly 5th and 6th). The drivetrain is fine with nearly 1500 miles on it now. The only problem now is with intermittent A/C............
Old Jun 19, 2005 | 05:19 PM
Lazerwolfe's Avatar
Lazerwolfe
From: I am Jack's out-dated Fight Club reference. MD
easy on the brakes
The C6 FAQ has a link to this subject. Do DocRing a favor and use it.
Old Jun 19, 2005 | 05:21 PM
Lazerwolfe's Avatar
Lazerwolfe
If you can, yes. More fun, nice scenery, and all the flexibility in speed that you will need.
Old Jun 19, 2005 | 05:38 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
This what I did also...
To C6 break in question???
Old Jun 19, 2005 | 06:46 PM
rm50's Avatar
rm50
2020 C8 of the Year Finalist - Unmodified
Take it easy the first 500 miles but don't "baby it". It is important that you let everything set properly but nobody is going to drive 55 and under for 500 miles.
Old Jun 19, 2005 | 07:13 PM
crabman's Avatar
crabman
easy on the brakes
Yep, when I put gears in my car the documentation had a little section on why you want to follow the breakin procedure. They stated that the gears would be stronger if broke in easy. It stated improper breakin could reduce gear strength by as much as 50%. Following proper breakin procedures would also reduce or nearly eliminate gear whine which can take up to 10000 miles to start showing up depending on just how much you abused them during the break in period. That is straight from the people that made the gears. You can make of this what you will but I thought some people might be interested.
Old Jun 19, 2005 | 08:38 PM
TheGreatOz's Avatar
TheGreatOz
Even if you paid full MSRP!
