DVD Nav Operation...
Old Jun 22, 2005 | 12:41 AM
purple heart's Avatar
purple heart
Default DVD Nav Operation...
1. After the DVD in installed in the radio, does it stay in after you've returned home after your trip till you need it again or do you remove the DVD after each use?
2. How do you turn off the Nav system if you decide not to go to your planned destination say, mid-way there?
Appreciate some help; don't recall seeing this info in the book but I may have missed it...?
Old Jun 22, 2005 | 01:11 AM
shopdog's Avatar
shopdog
Leave it in the drive, otherwise you get an error message every time you start the car.
Select cancel guidance from the route menu.
Old Jun 22, 2005 | 08:11 AM
footba4672's Avatar
footba4672
The DVD will also cost you a few bucks to replace if you lose it..Keep it in.
Old Jun 22, 2005 | 08:26 AM
lehew's Avatar
lehew
I agree. I never take the DVD out.
A bit more detail on cancelling guidance...
From the map screen, press the menu button. Then press "route options." From that screen, just touch "cancel guidance" and then "yes" to confirm.
Old Jun 22, 2005 | 10:22 AM
ALFA 1's Avatar
ALFA 1
Probably the reason for so much dissatifaction with the 'useability' Four operations just to turn it off! That's what happens when you engineer for the chip instead of the human.
Old Jun 22, 2005 | 01:27 PM
mforman42's Avatar
mforman42
Theoretically, you can cancel from the voice recognition. I say theoretically because I can't get my voice recognition to recognize anything.
It responds to 'FM1' with 'reset home?' and 'yes' with 'displaying gas station icons'.
To DVD Nav Operation...
