Slow out of the gate...by this time next year you'll be able to buy more cargo mats, in various versions, then thought possible. It seems a lot of the aftermarket crowd takes a while to engage with new fit/finish requirements.
Does/will Lloyd make a cargo mat that doesn't cover the cubby holes?
I have found it to be a pretty trivial exercise to lift up a corner of the rear mat to get to either of the doors. Unless you were going to stick some speakers or ?? in the storage bins and need them uncovered, to me the mat looks better covering the entire rear area.
I'm not a big fan of the storage bins, and the lloyds mat covers them up very nicely. However, I'm installing some inverted subs into the cubby holes, and need to have that area open. I toyed with the idea of having the mat cut and rebound on the edges, but I figure I'll just wait till one is available.
What I will miss in the meantime is the sound deadening the thick mat provides.
I like the look of the one-piece mat plus it helps to quiet the interior.
