Who has no problems...
Old Jul 2, 2005 | 03:06 PM
  #41
shopdog's Avatar
shopdog
Originally Posted by famous1
About 2100 touble free miles... What did they do to destroy your tire? Run over a nail?
They ran over what looked like a steel body clip. It put a 1 inch cut in the tire, not repairable.
Old Jul 2, 2005 | 03:11 PM
  #42
cmb13's Avatar
cmb13
No problems that I haven't caused! Power top wouldn't go up, but only because the fabric separating the trunk from the top wasn't tight enough. Lost my stainless O-R letters (accessories), took a month to get new ones.
Old Jul 2, 2005 | 05:12 PM
  #43
chucky7's Avatar
chucky7
Default No problems
2600 miles and smooth sailing
Old Jul 2, 2005 | 05:17 PM
  #44
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
14,200 mi Z51 6Spd 1SB
Only persistant problem is dash warning:
Ck ABS - Shocks Inop - Stab Control Inop - Svc Vehicle Soon
Another problem I had to day was that my DIC said:
"Quit messing with my shroud - make that Big Honker go away"
Old Jul 2, 2005 | 05:42 PM
  #45
ss409cid's Avatar
ss409cid
1900 miles radio replaced and have to keep fighting off the Chicks...
Old Jul 2, 2005 | 06:07 PM
  #46
juiceman03070's Avatar
juiceman03070
St. Jude Donor '08
Default vin 2048
6500 miles of smiles...............
Old Jul 2, 2005 | 06:15 PM
  #47
AraiGP4's Avatar
AraiGP4
April build, mid-May delivery. Z-51, 1SB, XM, polished wheels, 6MN. 1100 miles. absolutely no problems. great car. The Carrera 996 it replaced had to have the windows reseated to eliminate serious thumping noise, new battery, new alternator, all in 15K miles. the C-6 is faster, more fun, (so far) more reliable, more comfortable and better looking. Not bad, considering it cost $25K less.
C6 needs bluetooth, change holder, a coat hook. and tires with a better rain capability. Other than that, it is an absolute home run and the most capable sports car i've ever owned. my first Corvette, but it won't be my last.
Old Jul 2, 2005 | 07:58 PM
  #48
19stingray70's Avatar
19stingray70
9100k and it's all good
Old Jul 2, 2005 | 10:12 PM
  #49
Jbal's Avatar
Jbal
2100 mi, & just a slight rattle in the left side of the rear hatch. Just disappeared after about 700-800 mi.
A fabulous Car!!!
Old Jul 2, 2005 | 10:18 PM
  #50
Beach21's Avatar
Beach21
No problems! 3K miles
Old Jul 2, 2005 | 10:20 PM
  #51
GGWOODY's Avatar
GGWOODY
From: Buena Park, CA I seem to have left my electrolytes with your daughter
4400 miles, and One toasted Slave Cylinder, one faulty RF antenna----driver's side.....that's it. Even though I had a Major MAJOR issue, I am as happy as can be with the "Blue Monster"
Old Jul 2, 2005 | 10:29 PM
  #52
thinkdave's Avatar
thinkdave
Cruising
LMB Coupe 1SB, NAV, Polished, Dual top kit.
1200 miles, no DBS, no LOW/Missing oil....but a small oil leak that appears under the car on the drivers side just in front of the LF wheel
about 1.3' in from left side of car. Is motor oil, cannot tell where from.
any hints???
Old Jul 2, 2005 | 10:37 PM
  #53
nascar5212002's Avatar
nascar5212002
800 miles no problems so far
Old Jul 2, 2005 | 11:04 PM
  #54
Mr.clean's Avatar
Mr.clean
Lets see ...
I have eaten through 3 quarts of oil in 1500 miles
gasoline cant be put into the car it comes outof the nozzle or comes out of the bottom of the car which is always a thrill when people are smoking nearby (which happened the other day) kinda makes your hair stand on end when you look down and you feet are wet cause the gas is spraying out of the car
I get about 8 miles to the gallon
both fuel senders are bad so it runs kinda rough
this is my first GM product in 20 years the dealer is cool and apologetic
Luv the car but these problems are pretty nuts
Old Jul 2, 2005 | 11:08 PM
  #55
Guitarstar's Avatar
Guitarstar
No Problems with the smiling Great White. Just a little raddle from the glove box. I fixed it with a 1 inch foam strip.
Old Jul 2, 2005 | 11:35 PM
  #56
3car5's Avatar
3car5
Dead battery at 2800 miles. Down about two hours. Perfect other than that now with 3800 miles.
Old Jul 2, 2005 | 11:37 PM
  #57
verbatim_dkw's Avatar
verbatim_dkw
I have 17987 miles on my C6 - I had it lowered, put Borlas, and replace the stocked breather - the only problem I had is the signal bulb right bad - replaced it and I had to add some power steering fluid
To Who has no problems...
Old Jul 2, 2005 | 11:43 PM
  #58
TedG's Avatar
TedG
8000 and no problems.
Old Jul 2, 2005 | 11:55 PM
  #59
Low12s's Avatar
Low12s
From: Life isn't about waiting for the Storm to pass, it's about learning to dance in the Rain.
I thought the thread was no problems...
Old Jul 3, 2005 | 12:27 AM
  #60
craigcurry's Avatar
craigcurry
1200 miles with fuel sending unit gone bad and gas cap will nit lock up. Love the car, just hope that my dealer service department can replace the FSU and not cause any other problems.
