Shell V-Power
Old Jul 2, 2005 | 01:13 PM
b4i4getit's Avatar
b4i4getit
Default Shell V-Power
Does anybody have any opinion on Shell V-Power gas ? Is it any good ?
There is a gas station very close to me that I would like to use but I don't know if V-Power is a potential problem. I recall that Shell was in a class-action suit a few years ago because some additives in their gas were screwing up the sending units in some cars.
http://www.shell.ca/code/library/new...an07_fuel.html
And now I read that last year they had a sulfur problem.
https://www.lawyersandsettlements.com/case/shell2
Is using Shell gas a potential problem ?
Old Jul 2, 2005 | 01:43 PM
Blue Lion's Avatar
Blue Lion
Shell makes the VPower out to be something you can't get at other major stations. I bet it's good gas but not better than BP, Chevron, etc.
The problem awhile back (maybe 18 months?) was traced to 1 refinery that produced gas that had too much sulphur I believe. If you have a Shell nearby and it's what you want, I'd use it. I prefer Chevron myself.
Old Jul 2, 2005 | 01:46 PM
Pipedreams's Avatar
Pipedreams
St. Jude Donor '06-'07
It's listed in the FAQ's under top tier gas and is the only thing that has been in my car since I got it
Old Jul 2, 2005 | 02:10 PM
bangbgC6's Avatar
bangbgC6
V-power is the only gas I've run in the Vette since new. No problems with respect to fuel gauge, fuel sendeer, or fill-ups.
Old Jul 2, 2005 | 04:13 PM
LDB's Avatar
LDB
I posted a thread a few months ago titled "gasoline facts" (and a related one titled "oil facts"). They got a lot of attention and many replies at the time, but like all other threads, fade with time. You can find them by using those titles in the "search this forum" function. They are relevant to your question. Shell indeed had an isolated problem with sulfur, but they corrected it and stood behind any damages caused. This is typical of majors. They are less likely to get you in trouble in the first place, and if they do happen to screw up, as all humans do from time to time, they will stand behind it. In general, you are much safer with the major brands. V-Power has some advantages to their additive package. They may be better, but are certainly not worse than others. The thing about additives is that there is no such thing as the universally better additive. Some are better in some areas, some in others. If it keeps valves a smidgen cleaner, you can bet it won't do quite as good on injectors. Overall, you shouldn't hesitate to use Shell, or other majors, in your car. As several of the replies in the threads point out, you are also often OK with the cheapos. But you never know for sure. So it's all about how much you are willing to risk to save a few cents.
Old Jul 2, 2005 | 04:14 PM
Lazerwolfe's Avatar
Lazerwolfe
From: I am Jack's out-dated Fight Club reference. MD
I never liked the taste of Shell to be honest.
Old Jul 2, 2005 | 04:17 PM
shopdog's Avatar
shopdog
First you have to understand that gasoline is a fungible bulk commodity, delivered by mass pipeline. It is not segregated by brand. The gas you buy at Sam's Club or Kroger is the same gas Shell sells. The *only* difference is the additive package added by the truck driver who delivers the gas to a retail station. That's a couple of Kool Aid size packets dumped into a 10,000 gallon tanker truck load.
Does the make up of the additive package matter? Yeah, over the long term it helps keep injectors cleaner, but all retail gasoline has to have additives that meet a particular EPA standard. Top Tier suppliers go a bit above and beyond that to earn their Top Tier ranking. Shell V-Power has the Top Tier ranking. It is just as good as the gas sold at QuikTrip, The Pantry (Conoco), or at a higher price Chevron station. All of whom are Top Tier ranked for their additive packages. (As noted above, the actual gasoline sold is all the same, coming out of the same tank at the pipeline terminal, only the about 4 oz of additives mixed into 10,000 gallons of gas differ between one brand and another.)
Old Jul 2, 2005 | 04:22 PM
Lazerwolfe's Avatar
Lazerwolfe
Yep, I saw a thing about it on the history channel.
Old Jul 2, 2005 | 04:29 PM
easyrider13's Avatar
easyrider13
These are the gasolines you want to feed your Vette:
http://www.toptiergas.com/retailers.html
Shell is the only top tier gas I can get in NJ, and I use Chevron in FL.
Old Jul 2, 2005 | 05:33 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
A top shelf product. Can't go wrong there
Old Jul 2, 2005 | 07:46 PM
ASZ2222's Avatar
ASZ2222
Shell V-Power is all I use.
Old Jul 2, 2005 | 08:16 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
In my C5 is use Shell, Amoco/BP, or Exxon/Mobil. No problems with any of them.
Old Jul 2, 2005 | 08:48 PM
b4i4getit's Avatar
b4i4getit
Thanks everyone. I feel much better about my decision to use Shell.
Old Jul 2, 2005 | 10:31 PM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
There is a noticeable difference between Chevron & other brands in our 427. However, if Chevron is not available, Shell is our second choice.
Old Jul 3, 2005 | 12:52 AM
ZL-1's Avatar
ZL-1
Very good post shopdog, all very true...saved me a bunch of typing.
Old Jul 3, 2005 | 06:29 AM
LDB's Avatar
LDB
This is true if you are in an inland area served by a major, "common carrier" pipeline such as Colonial or Explorer. This is not true if you are on the coast or a river, served by tankers and barges. If you happen to be in the latter category, and a large fraction of the US is, you are exposing yourself to greater distribution risk by going with the cheap guys.
Old Jul 3, 2005 | 08:49 AM
Tom/99's Avatar
Tom/99
I've been using Shell gas in all my vehicles. The only time I vary, is if I'm on the road and there are no Shell stations to be found. Since I've been using Shell, I've had no fuel related problems.
To Shell V-Power
Old Jul 3, 2005 | 08:58 AM
PA Coach's Avatar
PA Coach
Here in Pennsylvania, we are treated to 'reformulated gasoline' from May through September to help our environment. Cough. Anyway, I kind of look at reformulated gas as being akin to dumping a gallon of water into your tank for evey 20 you put in. The knocking, the pinging....the struggle to get up a hill in my SUV.....
Anyway, we've been treated to myriad reports lately about 'premium gas' what with the soaring price at the pump. Local 'experts' have been talking about how there is little to no difference between regular unleaded (87) and premium (93). My Jaguar S would strangle one of these experts if it could.
I would think this is the same case for Vettes, no?
Old Jul 3, 2005 | 09:38 AM
toedoc's Avatar
toedoc
I have stuck with the top tier gas and have had no probs, except that I have to fill the corvette to often(high revs) if you consider that a problem
Old Jul 3, 2005 | 10:25 AM
shopdog's Avatar
shopdog
It is true that in an area served by tankers or barges, stations getting gas that day will get the gas of the refinery that filled the tanker or barge. That can change from one delivery to the next. But the same is true with pipelines. One batch will be from one refinery, the next from another. The only difference is that the pipeline supplied areas get more batches, and they mix in the large storage tanks at the pipeline terminal. So areas served by pipelines will have more uniform product day by day than areas with more sporadic deliveries.
