Installed XM
Old Jul 2, 2005 | 05:08 PM
Boozman's Avatar
Boozman
Default Installed XM
Commander in the ash tray no holds and works great, I put the small ant. on the dash doesn't get in the way it's so small.
Old Jul 2, 2005 | 06:01 PM
sanspeur's Avatar
sanspeur
What unit did you install? How does it tie in to the radio? And how did you route the wire up to the antenna on the dash?
Old Jul 2, 2005 | 06:39 PM
Boozman's Avatar
Boozman
Sorry I worked with a freind who does this everyday I was the helper. He ran the wire under the dash a took the driver side window pollow off and came up through there and pushed the wire down between the dash and the window and stopped in the middle and used double sided tape to hold the ant. The commander was put in with double sided tape so that we can get it out when they come up with the interface for the C6 so we can install the GPS with XM built in.
Old Jul 2, 2005 | 10:42 PM
FastMover's Avatar
FastMover
From: Tellico Plains, Tn "Wolf" Official Corvette Guard Dog
Cruise-In II Veteran
Cruise-In III Veteran
I did the same install a while back, here is a link to the details, It really sounds good, any questions PM me
http://forums.corvetteforum.com/show....php?t=1042327
Old Jul 2, 2005 | 11:22 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
To Installed XM
