Ebony Interior
Old Jul 3, 2005 | 08:02 AM
montivette's Avatar
montivette
Default Ebony Interior
OK I have had the car for like two days and have a minor issue. White powder like residue marks all over the ebony interior. Just touch interior anywhere and it seems to leave marks where you touch.
What have others found to be best to keep it looking nice? I have bought some low gloss Armor All mainly because that was about only stuff I saw at the store which was low gloss. I have not put it on yet.
I know the GM people said in the informational DVD which came with car how the matte interior finish was done on purpose as glossy plastic interiors were said to look cheap. But I loved the glossy black interior on my 1991 and after an entire summer it still looked clean and never had marks on it. In contrast this flat grayish black interior they call ebony seems to show everything.
Has anyone taken the gloss armor all product to it? I would think that the gloss stuff would soak in and make it where people touch the vinyl without leaving marks due to oils in the skins sucking into the flat finish. But I am sure it will create a nice glare on the window. Or will just a good coating of not gloss stuff put some moisture in the vinyl and keep it from showing so many marks?
Old Jul 3, 2005 | 08:32 AM
Scruff Vette's Avatar
Scruff Vette
I use Aromor All "Detailers Choice" on my Ebony interior about once a month. Looks great and no problems with scuff marks or white areas. I had the same problem until I started using it.
Old Jul 3, 2005 | 08:49 AM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Have used 2 items on the plastic.
Armorall Low Gloss - was OK
Stoner's Trim Shine - think that's the effect you're looking for.
Old Jul 3, 2005 | 08:56 AM
montivette's Avatar
montivette
Do not see anything called detailers choice on Armor All Site:
http://www.armorall.com/prodcat/index.html
Not sure about trim shine. Their site kind of makes it look like and exterior product similar to a tire spray. But I suppose it would take flat black plastic and make it shine. Are you using it yourself or just suggesting I use it cause I prefer a more glossy finish?
http://www.trimshine.com/index.htm
Mainly I just want to keep all the marks from appearing as much as possible and if it can be done with a more stock looking matter finish that would be fine. If it can't then I will move on to glossy stuff.
Old Jul 3, 2005 | 09:31 AM
ufso's Avatar
ufso
This has been discussed a million times. Don't put anything on it. Use a moistened soft towel (dark) or diaper and let air dry. Dust off fibers with small Cal Duster. Use Mr. Clean Eraser for door bottoms.
Once you put something on it, you'll always have to do it. The culprit is women with cream on their hands and you if you do.
The ebony is less forgiving than the C-5's, but don't worry about it. It'll take a tad more care when you detail the car.
Good luck!
Old Jul 3, 2005 | 10:50 AM
BIGGGIE's Avatar
BIGGGIE
St. Jude Donor '05-'06-'07-'08
Good luck!
Old Jul 5, 2005 | 01:33 PM
AraiGP4's Avatar
AraiGP4
Good luck!
Old Jul 5, 2005 | 01:49 PM
calemasters's Avatar
calemasters
Good luck!
I also agree. I would not use a product such as Armor All. I just damper a cotton towel with Windex to clean the I.P. and door trim panels. I have the Cashmere interior, so at the bottom of the driver's door where I get scuff marks, I use the Mr. Clean eraser, as mentioned above.
Old Jul 5, 2005 | 02:01 PM
jschindler's Avatar
jschindler
I use leather conditioner on all the black surfaces in my interior. I found with my last convertible, that becuase I drive with the top down a lot that it really gets "dry" looking after a while. I used a leather conditioner, and six months later it still looked great.
The key to me is to put it on and just let it soak in. I wait at least a few hours, then go over it with a slightly damp rag. I don't use any of the "spray" conditioners like Armor All because I don't think it really moisturizes the material like a leather conditioner does.
Some may dissagree with my advice, and that's fine. But it works for me and I only have to do it about twice a year.
Old Jul 5, 2005 | 02:15 PM
Lazerwolfe's Avatar
Lazerwolfe
From: I am Jack's out-dated Fight Club reference. MD
Let me know if [censored]
Old Jul 5, 2005 | 02:56 PM
Boozman's Avatar
Boozman
I use 303 on all the int. it helps with protecting and UV
Old Jul 5, 2005 | 03:03 PM
Braced's Avatar
Braced
Just use a damp sponge and a good dry cotton towel. I agree with the above post that if you put something on the interior you'll have to keep using it.
Old Jul 5, 2005 | 03:08 PM
3car5's Avatar
3car5
This post just wouldn't be complete without a Zaino comment.
Most of the time I use a damp cloth to wipe it down. Twice so far I have used the Zaino leather spray conditioner to go over the ebony. It seems to allow for an easier clean up for several weeks after application and does not leave any sheen to the interior.
Old Jul 5, 2005 | 07:16 PM
b4i4getit's Avatar
b4i4getit
I don't understand how you can moisturize plastic. It is not porous since it is not an animal skin like leather. A damp rag should do just as well in my opinion.
To Ebony Interior
