What is "normal" engine temp. for C6?
Old Jul 4, 2005 | 10:23 PM
purple heart's Avatar
purple heart
Default What is "normal" engine temp. for C6?
I only have about 260 miles on the car and lately had time to start noticing different things. For example, the coolant temp. seems to stay around 199-201 degrees. Is this normal for the C6 (during the break-in period)? Not that the break-in period should matter. I installed a billet aluminum grill recently and I think the car was running around the same temp before but I'm not sure. Would appreciate any imput on this so I can be sure the car isn't driving on the hot side with this grille installed.
Old Jul 4, 2005 | 10:35 PM
calemasters's Avatar
calemasters
You have a 195 degree F thermostat. Normal coolant temps can range from 190 to 225 degrees F. You will get a DIC "Coolant Over Temperature" message at 255 degrees.
Old Jul 4, 2005 | 11:03 PM
purple heart
Ahhhhhhhhh Good! Looks like the grille I installed has not affected the normal cooling capacity of the car. With the a/c off, its normal temp. seems to be 199-201 degrees F. Thanks, I feel better now-whew(as they say, eh?)!
Old Jul 4, 2005 | 11:05 PM
Vette_DD's Avatar
Vette_DD
Mine normally runs 197 to 203, coupe with auto tranny and base suspension.
Old Jul 4, 2005 | 11:39 PM
rwpatte's Avatar
rwpatte
190 to 192 at highway speed
Old Jul 5, 2005 | 12:06 AM
Rob4092xx's Avatar
Rob4092xx
The highest mine has hit is 213 on a hot Phoenix day (112 degrees)!
Old Jul 5, 2005 | 12:14 AM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
every time i have looked at it has been 196. ambient between 80-105
Old Jul 5, 2005 | 05:37 AM
purple heart
Default Thanks
Thanks alot y'all; according to your input, my C6 seems to be operating in the normal range(yours too, I guess) or were all over heating
At least now I can put that issue to rest; mine is auto, vert. base suspension and by the way, this is with the air off. Matter of fact, I've only used the air one time so far. Hard to put the damn top up. Great Car.
Old Jul 5, 2005 | 08:11 AM
legalgus's Avatar
legalgus
New Corvette magazine had an article about some C6 mods, including a 160 degree thermostat. Forget who was doing the mods (Cartech), but they made a heck of a difference with performance. Their main problem was the computer control. Appears there may be something in the works that'll hit the market later on. You might want to check the latest issue.
Old Jul 5, 2005 | 08:18 AM
ALFONSE's Avatar
ALFONSE
Mine usually runs between 190 and 200 degrees (Z51 Vert).
AL
Old Jul 5, 2005 | 11:58 AM
MitchAlsup's Avatar
MitchAlsup
Don't worry about anything under 215dF, and don't really worry until it gets above 220dF. These engines are designed to run hot, and the hotter they run the more efficient they become (fuel economy wise). Mine sees about 205s in traffic in Texas 102dF days.
To What is "normal" engine temp. for C6?
