I am adding a Corsa sport exhaust and X pipe tomorrow. A friend who is a truck mechanic, but not a vette expert, said I would have to make a computer adjustment after the install. Can you experts comment please?
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
Originally Posted by calemasters
You can not make any adjustments to the ECM. The integrator and block learn memory adjust as you drive.
About all you can do is to clear the ECM using a Tech 2 and let it re-learn. However, this will occur as your drive, even without an ECM reset.
the catback+x-pipe will not effect flow so much as to require a computer tune. but from what i've heard / seen on the forum changing intake may require a retune.
