Dead Vette...again!
Old Jul 9, 2005 | 12:30 PM
corvette05's Avatar
corvette05
Default Dead Vette...again!
WENT TO START VETTE THIS MORN AND GOT MESSAGE TO SERVICE COLUMN LOCK...WOULD NOT START...THEN ALL ELECTRICAL WENT HAYWIRE..THEN DEAD.....THIS IS SECOND TIME...DEALER HAD IT TOWED THIS MORN .. NO CHARGE...SLOTTED FOR DIAGNOSIS FIRST THING MONDAY MORN....NO DOUBT GM HAS A PROB WITH ELECTRICAL IN 2005 VETTE.
Old Jul 9, 2005 | 12:59 PM
Vette_DD's Avatar
Vette_DD
Bummer. Sure sorry to hear that. Hope it doesn't take them long to find & fix the problem.
You may also have a problem with your PC. I think the caps lock key is stuck down.
j/k, but typing in all caps is considered shouting.
Old Jul 9, 2005 | 01:08 PM
MikeNMaxZO6's Avatar
MikeNMaxZO6
That's not good! I didn't know there was a problem with the C6
Old Jul 9, 2005 | 01:13 PM
vrodder64's Avatar
vrodder64
What was the fix the first time you had issues with the electrical system?
Most of the time, in the C6, electrical problems can be traced to a faulty battery.
Don't blame the car if you are having reoccurring problems. Ask yourself if the dealership doing the work is performing the necessary repairs.
I hope you and your car are back on the road swiftly!
p/s
Don't need to shout in your email. Our hearing around here is just fine. Or...tell the cat to quit walking across the keyboard as you type.
Old Jul 9, 2005 | 01:19 PM
coolcat's Avatar
coolcat
No electrical problems to report with 13,000 plus miles on my C6. However the check engine light came on while driving Friday even though all the gages are reading normal. So I made an appointment to take it back to the dealer on Monday. Hope it's not the beginning of the dreaded crankcase pulley meltdown.
Old Jul 9, 2005 | 01:22 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
The dreaded column lock has followed the C6's???
Old Jul 9, 2005 | 01:47 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
Old Jul 9, 2005 | 01:57 PM
MARKAB_C6's Avatar
MARKAB_C6
2nd Gear
Mine has given me column lock as well, as a dead battery...no, did not leave anything on, and yes it was in reverse.
Onstar report OK...dealer could not find/duplicate problem.
Great car! Just the little things like this, and the DRL socket melt down, buzzing shifter and loud tranny noises that take away my initial joy.
Really does not make my day, when I finally get a day to drive my car and it won’t start.
Old Jul 9, 2005 | 02:02 PM
vette-oholic's Avatar
vette-oholic
Default Caps Lock?!
JeEz - I HoPe YoU GuYS ArE KIddING AbOUt the CAPS LOCK - Who ThE Hell CaReS IF ItS LoWeR CaSe OR NoT?!
Old Jul 9, 2005 | 02:06 PM
RJMan's Avatar
RJMan
Good one! You made my day
Old Jul 9, 2005 | 02:48 PM
BlackMark's Avatar
BlackMark
I agree with Vrodder64-a good share of the electrical problems in the C6 are probably battery related.A short inside the battery behaves like any other short in the electrical system,giving bizarre messages on the DIC.Make sure the dealer checks the battery thoroughly including a load test.I started developing erratic door lock operation in my work car a while back-a 2002 Toyota Celica GTS,though the car started just fine.One day at work,no start.Diagnosis was short in battery.New battery,and all problems went away.I put an Optima redtop in my C6 as soon as I got it home.I have had zero electrical problems so far.
Old Jul 9, 2005 | 03:06 PM
corvette05's Avatar
corvette05
Default Cap-lock ?
REALLY! WHO KNEW, WHO CARES.
Old Jul 9, 2005 | 03:08 PM
corvette05's Avatar
corvette05
Default Dead Vette
thanks for replys
Old Jul 9, 2005 | 03:17 PM
eagle123's Avatar
eagle123
Originally Posted by MARKAB_C6
...the DRL socket melt down, buzzing shifter and loud tranny noises that take away my initial joy...
These are new ones on me. DRL socket meltdown? Is this common across all C6s? Is the meltdown due to a bad connection, or bulb too hot? Maybe a resistor could be put in line to reduce wattage to these bulbs so that they are less likely to overheat? Who cares if they run dim, not me.
Buzzing shifter... ok, I've heard that one... but in some cases it was just a lose fitting **** which is easy to fix. Is there a problem with the shifter itself? I once had a car with a high quality but rattling shifter mechanism... drove me completely nuts... can't have that. I guess a Hurst could always be swapped into a C6, hopefully they don't rattle too.
Loud tranny noises??? I assume you have the manual. What noises and why?
Thanks.
Old Jul 9, 2005 | 04:22 PM
Vette_DD's Avatar
Vette_DD
Keep using them and find out.
Old Jul 9, 2005 | 10:07 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
Seems like could be battery issues. Not fully charged up or cannot hold a full charge. Under 12 volts real issues appear.
Old Jul 10, 2005 | 12:13 AM
shopdog's Avatar
shopdog
The computers tend to go nuts and spit out all sorts of spurious error messages when the battery voltage drops below 10.5 volts. When you get erratic behavior like this, always measure the battery voltage first.
Old Jul 10, 2005 | 11:25 AM
6speedC6's Avatar
6speedC6
Check your fuse box and see if you have a relay #46 and remove it. It stop my battery problem!
Old Jul 10, 2005 | 11:28 AM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Originally Posted by TommyV
To Dead Vette...again!
