Roof Panel Squeaking
Old Jul 16, 2005 | 06:37 PM
Isharted's Avatar
Isharted
Default Roof Panel Squeaking
My roof panel is making a lot of squeaking noise. I tried to tighten the torx screws on the release handles but they are very tight. Didn't really want to bother bringing it to the dealer so I thought I'd check with the CF experts first. Anyone have some suggestions?
Old Jul 16, 2005 | 06:42 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Silicone spray
Old Jul 16, 2005 | 06:50 PM
C8-Vette's Avatar
C8-Vette
Originally Posted by JFTaylor
Silicone spray
Silicone in the tube may be easier to use-Just put a little on a rag and wipe on both the gasket of the top and the car gasket-just a little. Use Dielectric Silicone-available any auto parts store-it's the same stuff we use on spark wires.
Or you can use 100 proof burbon-Just drink the burbon , and all noises disappear (J.F. 's idea not mine!!!)
Old Jul 16, 2005 | 07:06 PM
JFTaylor's Avatar
JFTaylor
St. Jude Donor '06
Originally Posted by c6vette
Silicone in the tube may be easier .....Or you can use 100 proof burbon-Just drink the burbon , and all noises disappear (J.F. 's idea not mine!!!)
Hea Buddy
Old Jul 16, 2005 | 08:24 PM
2bubbas's Avatar
2bubbas
Mine was really squeaking. I took it off and put it in the hatch. Hasn't squeaked since.
Old Jul 16, 2005 | 08:28 PM
JFTaylor's Avatar
JFTaylor
St. Jude Donor '06
KY Jelly is an option
Old Jul 16, 2005 | 08:30 PM
Boozman's Avatar
Boozman
I used the dielectic Silicone which worked great.
Old Jul 16, 2005 | 09:03 PM
JFTaylor's Avatar
JFTaylor
St. Jude Donor '06
Default Yo Booze
Sounds like something you have to go to a registered explosives store to buy dielectic Damn
Old Jul 16, 2005 | 09:47 PM
cerino2000's Avatar
cerino2000
If its like mine, it isn't necessarily the weatherstripping that is squeaking. It's internal to the top. In other words, the squeaking isn't coming from the edges, it is in the middle of the top. Best I can tell, the must have some styrofoam in between the headliner and the top. I think mine got jarred loose which is causing the squeaking.
So, does yours seem like it is squeaking at the edges where the weatherstripping is or more from the middle?
Also,
By chance, have you taken your car to the drag strip?
Old Jul 16, 2005 | 09:51 PM
Pipedreams's Avatar
Pipedreams
St. Jude Donor '06-'07
Do a search I am getting worn out answering the same question over and over again
To Roof Panel Squeaking
