Oil changes
Old Jul 19, 2005 | 02:44 AM
LS WON's Avatar
LS WON
Default Oil changes
Does the magnetic oil plug for the C-5 fit the oil drain plug in the 2005 C-6?
Old Jul 19, 2005 | 03:07 AM
shopdog's Avatar
shopdog
Yeah, but aluminum isn't attracted to a magnet.
Old Jul 19, 2005 | 03:16 AM
gota07's Avatar
gota07
Cruise-In VIII Veteran
I know the block and some of the other internal parts are aluminum, but are there no wearable steel parts at all in the LS2?
Old Jul 19, 2005 | 03:20 AM
LS WON's Avatar
LS WON
Default So the final question is should or shouldn't you use a magnetic oil plug in the C-6?
Or just use the oil plug that came with the car.
Old Jul 19, 2005 | 03:58 AM
shopdog's Avatar
shopdog
The crank is iron and the rods are steel, but they run in bearings and should not shed any material as long as the bearings haven't failed. At that point, catching iron particles is pretty much moot, ie the engine is trash anyway. The cylinder sleeves are iron, and the rings are high chromium steel. These will experience some wear, but if the oiling system is doing its job, very very little between oil changes. Over the course of 100,000 miles or so, wear will accumulate, a few thousandths worth, but a magnetic drain plug really doesn't do anything useful about that. Any wear particles will either be so small they'll stay suspended in the oil, or if larger than 10 microns, will be caught by the filter.
Old Jul 19, 2005 | 04:22 AM
gota07's Avatar
gota07
That explains it, thanks ShopDog.
Old Jul 19, 2005 | 09:09 AM
Michrider's Avatar
Michrider
If you use a magnetic drain plug on a brand new vehicle, you'll see a glob of iron fillings attached to it at the first oil change. After that nothing, unless of course something breaks.
Done it a hundred times, cars, motorcycles... they all shed a little metal when new. Normal aspect of using mass produced parts.
So if your already past the first change probably wont do a thing. Must be some value to it, GM puts a magetic drain plug in the highest volume vehicle produced - C/K trucks. Why the Vette using the same engine family doesn't get one is a mystery. Maybe they needed to save a gram of mass and 2 pennies.
Old Jul 20, 2005 | 03:42 AM
LS WON's Avatar
LS WON
Default The magnetic oil drain plug would be for after the car has been broken in.
To Oil changes
