A6 Will be available
Old Aug 1, 2005 | 01:21 AM
AMF's Avatar
AMF
Default A6 WILL BE Available For '06
Good News (for those who care))
Just learned that A6 will be available. Will get more details.
Old Aug 1, 2005 | 01:25 AM
AMF's Avatar
AMF
Some other '06 for sures:
6-speed Paddle Shift automatic transmission available on Coupe and Convertible
Three-spoke, 370 mm (9.4 in) diameter steering wheel
Advanced dual-stage frontal air bags with GM Passenger Sensing System
XM Satellite Radio included with Bose stereo (48 states)
Two exterior colors: Velocity Yellow Tintcoat and Monterey Red Metallic Tintcoat
Titanium gray interior color
Storm Gray convertible top color
Old Aug 1, 2005 | 01:30 AM
AMF's Avatar
AMF
More INFORMATION:
2006 CORVETTE: Z06 HITS THE GROUND RUNNING; NEW SIX-SPEED AUTOMATIC AVAILABLE FOR COUPE AND CONVERTIBLE
Model year 2006 will always be known as the year the 505-horsepower* Z06 was let loose on the sports car world. With its 505-horsepower (377 kw) LS7 7.0L engine, racing-bred suspension, hydroformed aluminum frame and unique bodywork, the Z06 is the fastest, most technologically advanced production model in Corvette’s 53-year history.
Performance enhancements also are found on ’06 Coupe and Convertible models, with the availability of a new electronically controlled 6-Speed Paddle Shift transmission with automatic modes. The transmission has three driving modes – Drive, Sport and Paddle Shift – and a wide, 6.04:1 overall ratio that enables a balance of stirring acceleration and excellent fuel economy.
Other changes for 2006 Corvettes include a new three-spoke, 370-mm-diameter (9.4 inches) steering wheel. The wheel is smaller in diameter than the previous steering wheel, allowing the driver to maintain a “tighter” feel on the wheel and help improve turn-in response. The three-spoke design is characteristic of a sporty design that is being implemented in other performance-oriented Chevrolet vehicles.
Old Aug 1, 2005 | 01:45 AM
AMF's Avatar
AMF
MORE:
GM Passenger Sensing System – Replacing the previous manually controlled air bag switch, all ’06 Corvettes come with advanced dual-stage frontal air bags with GM’s Passenger Sensing System (PSS). PSS uses the latest sensing technology to turn the front passenger air bag on or off. If the sensor system detects an unoccupied front passenger seat or the presence of a smaller occupant, the front passenger air bag is designed to automatically turn off so it would not deploy in the event of a frontal collision. A status indicator on the inside rearview mirror alerts occupants that the passenger air bag is on or off.
Old Aug 1, 2005 | 01:47 AM
AMF's Avatar
AMF
MORE:
XM Satellite Radio combined with Bose audio – For vehicles sold in the 48 contiguous states, XM Satellite Radio is included with the uplevel Bose audio system. The XM radio antenna is “hidden,” allowing for a smoother exterior appearance.
Old Aug 1, 2005 | 01:49 AM
AMF's Avatar
AMF
MORE:
6-Speed Paddle Shift automatic details
The new electronically controlled 6-Speed Paddle Shift automatic transmission is one of the most technologically advanced transmissions in the industry, featuring clutch to clutch operation, manual control shift operation and an integrated 32-bit electronic controller. A wide, 6.04:1 overall ratio helps deliver exciting acceleration performance along with excellent fuel economy.
The six forward gears have smaller “steps” between them, which enhances the feeling of performance and smoothness. The smaller steps also enable a steep, 4.02:1 first gear, which provides an improved-performance launch feel when compared with the previous four-speed automatic’s 3.06:1 first gear. There are two overdrive gears: a 0.85:1 ratio in fifth gear and a 0.67:1 ratio in sixth. The final drive ratio of Corvette models equipped with the new transmission is 2.56:1.
Technological sophistication is exemplified by two electronically controlled automatic modes, Drive and Sport; plus manual Paddle Shift. The Drive mode follows a specific shift schedule of predetermined shift points, while the Sport mode enables Performance Algorithm Shifting (PAS). PAS modifies shift patterns when performance driving is recognized by the controller. The Drive mode optimizes shifts for smoothness, while the Sport mode enables firmer shifts for better performance. With the Paddle Shift mode, gear changes are made with manual control paddles located on the steering wheel.
The performance and functions of the six-speed paddle shift transmission with automatic modes are guided by an integrated controller. The controller is located inside the transmission, reducing complexity. A new 300-mm torque converter, new rear bell housing, new driveline support and revised-length driveshaft also support the transmission’s integration into the Corvette
Old Aug 1, 2005 | 01:55 AM
AMF's Avatar
AMF
MN6 LISTED AS STANDARD
A6 LISTED AS OPTIONAL (This probably means there is a charge for the A6)
Old Aug 1, 2005 | 01:59 AM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
O.k. where did this come from?
Old Aug 1, 2005 | 02:01 AM
AMF's Avatar
AMF
Transmissions
6-speed manual
6-speed manual, w/ optional Z51 Performance Package
6-speed paddle-shift automatic
Application:
std
opt
opt
Gear ratios (:1):
First:
2.66
2.97
4.02
Second:
1.78
2.07
2.36
Third:
1.30
1.43
1.53
Fourth:
1.00
1.00
1.15
Fifth:
0.74
0.71
0.85
Sixth:
0.50
0.57
0.67
Reverse:
2.90
3.28
3.06
Final drive ratio:
3.42
3.42
2.56
This info needs to be spread out horizontally. It did not cut 'n paste right.
C6Harley's Avatar
C6Harley
thanks for the info! Where did you get it?
Old Aug 1, 2005 | 02:02 AM
AMF's Avatar
AMF
It is straight from GM. I know you were waiting for this info. I know I sure was.
Old Aug 1, 2005 | 02:03 AM
vetteship's Avatar
vetteship
Originally Posted by AMF
MORE:
Thanks for the info, it's about time they add systems like that one, my $20K company issued daily driver has it. You say all '06 Vette, I'm assuming ZO6 included
TommyV's Avatar
TommyV
So the A6 is the only auto, but it's an option?
Old Aug 1, 2005 | 02:06 AM
AMF's Avatar
AMF
Yep NO A4 at all. There is the M6, the Z51 M6, and the A6. M4 gone!
Old Aug 1, 2005 | 02:09 AM
TommyV's Avatar
TommyV
How did you get it??
Old Aug 1, 2005 | 02:10 AM
C6Harley's Avatar
C6Harley
Old Aug 1, 2005 | 02:13 AM
AMF's Avatar
AMF
Im Dave Hill incognito.
To A6 Will be available
Old Aug 1, 2005 | 02:16 AM
AMF's Avatar
AMF
It's on the GM media web site to be released Aug. 1. It must be 12:00 somewhere east of Colorado because I got the info before Aug. 1.
Old Aug 1, 2005 | 02:26 AM
AMF's Avatar
AMF
A6 gas mileage TBD. Same with the Z06.
Old Aug 1, 2005 | 02:29 AM
AMF's Avatar
AMF
Fuel Recommendation:
C6 - Premium Recommended
Z06 - Premium Required
