Help with Interior Squeaks!!!
Old Aug 2, 2005 | 11:24 AM
reallygeeky's Avatar
reallygeeky
6th Gear
Default Help with Interior Squeaks!!!
Hi guys,
I have a z51 Coupe with about 1200 miles on it. (Just over a month old). Last Saturday afternoon, I was off playing some tennis. It was a very hot afternoon here in Austin, TX and unfortunately I couldn't find any shade for the car. When I got back in the car and drove off, there was a very audible rubber squeaking noise coming from above and behind me. This noise is loud enough to be heard over the radio set at normal volume and is annoying as all hell. I'm pretty sure it's coming from the hatchback seals (since I had the roof off the next day and it still made the sound). The noise has persisted and is very very very annoying.
My theory is that seals dried out in the heat of the afternoon and need some silicone lubricant. Can any of you guys suggest a product? Or alternatively, should I take the car to a dealership and have them look at it (if so, can you please suggest a dlr in the Austin area... I took courtesy delivery at Champion Chevy and wasn't 100% impressed with them). I'm starting to miss my Porsche 911 (I had a similar problem with it but at least I wouldn't have to worry about the service at the dealership).
Old Aug 2, 2005 | 12:00 PM
NavyC5's Avatar
NavyC5
CI 3-4-5-6-10 Veteran
St. Jude Donor '03-'06-'08-'09-'10
From what I've been reading, any good silicone spray will do the trick
Old Aug 2, 2005 | 12:50 PM
Guitarstar's Avatar
Guitarstar
You have a couple of options. A silicone grease not spray will give a more effective lubricant, You also can try F21 by turtle wax in the green bottle and apply it, 'Its like armour All' but better. Also a clear grease for pool pump seals is good as well. I do not recomend the grease by the window seals as this will smudge your windows everytime they go up. Here in las Vegas it goes up around 117 & my seals are perfect. My glove box rattles.
To Help with Interior Squeaks!!!
