Fuel Sensor question
Old Aug 6, 2005 | 12:52 PM
adwise's Avatar
adwise
Default Fuel Sensor question
I've experienced the dreaded fual sensor problem three times. All were half way through 100 mile trips with the tank about half full. The fuel gauge went to empty and then jumped back on and off. It has never happened during my daily driving. Most of my driving is within 20 miles of home. I have 4,000 miles on the car.
My question is... Must the card be changed? Can I just live with it (to avoid the dealer hassle) without added damage to the car?
Old Aug 6, 2005 | 01:07 PM
Nel727's Avatar
Nel727
Earlier posts have pointed to some sensitivity to brands of gasoline. If you did not experience the problem in daily driving and it showed up on a trip, then a change in your ordinary gasoline may have caused it (if you routinely use the same gasoline at home). If so, then returning to your normal gasoline could solve the problem. If not, then....hmmm.
Old Aug 6, 2005 | 01:38 PM
TRAYC7's Avatar
TRAYC7
NCM Ambassador
CI-3-4, 9 & 10 Car Show Winner
CI-3-4-5-6-7-8-9-10 Veteran
St. Jude Donor '04-'05-'06-'07-'08-'09-'10,'14, '16
St Jude Fedex Bowl Donor '09
As withi my C5... I stayed away from BP gas... it has higher sulphur content (just my experience)... after I stopped using that in my C5, I never had the issue again... now I only use Shell, Citgo... havent had the issue on the C6...
Old Aug 6, 2005 | 01:42 PM
VET4LES's Avatar
VET4LES
It's not fuel related. Check out the FAQ section. It will only get worse. The same thing happened to me. I waited until the new and revised card was available and then had it replaced. It took about 4 or 5 hours and I have not had a problem since. Good luck.
Old Aug 6, 2005 | 01:44 PM
Mocoso's Avatar
Mocoso
Problem with leaving it be is that the check engine light gets triggered by the fuel send unit issue - I would worry if you had "other" issues which were serious enough to trigger check engine light but you ignored them as you thought the light was due to fuel send unit. If you can find a dealer that has done a few of the units on C6 already you shouldnt have any troubles at all. By now most dealers should know how to swap the cards without causing collateral damage. I guess you could ask them to have the check engine light not trigger on faulty fuel send unit but I doubt they will agree to it for warranty issues.
Old Aug 6, 2005 | 01:47 PM
arcticblast's Avatar
arcticblast
Cruise-In VI Veteran
Cruise-In VII Veteran
Hey Tracy,
BP gas must be getting better. That's my normal brand and I haven't had any problems with it. Take care,
David
Old Aug 6, 2005 | 01:48 PM
krusty's Avatar
krusty
Had The New Fuel Card Installed Two Tankfulls Ago The Problem Came Back For About Ten Miles Then No Problem We Will See How Long It Lasts.
Old Aug 6, 2005 | 01:55 PM
adwise's Avatar
adwise
Has anyone had the fuel sensor changed on Long Island? Would you recommend the dealer you used?
To Fuel Sensor question
