dry sump system
Old Aug 6, 2005 | 06:15 PM
MIKLL's Avatar
MIKLL
Default dry sump system
can someone please explain the difference in the dry sump oil pump in the new Z06 and the system that is in my 05 C6?...thanks...Mike
Old Aug 6, 2005 | 06:28 PM
Gary C's Avatar
Gary C
Dry sump oiling system
The LS7 has a dry-sump oiling system designed to keep the engine fully lubricated during the high cornering loads the Corvette Z06 is capable of producing. An engine compartment-mounted 8-quart reservoir delivers oil at a constant pressure to a conventional-style oil pump pick-up at the bottom of the engine. The pressurized oil feed keeps the oil pick-up continually immersed in oil at cornering loads exceeding 1 g.
Oil circulates through the engine and down to the oil pan, where it is sent back to the reservoir via a scavenge pump. The large-capacity reservoir, combined with a high efficiency air-to-oil cooler, provides necessary engine oil cooling under the demands of the engine’s power output. With the dry-sump system, oil is added to the engine via the reservoir tank – which includes the oil level dipstick.
Your system has a oil pick up in the pan.
Old Aug 6, 2005 | 06:30 PM
Gary C's Avatar
Gary C
and click here
To dry sump system
