Burnin' Oil at 3000 miles?
Anyone burning oil or having to add any? I just hit 3K and the oil was down to the lowest little hole on the dipstick, though I guess this is still in the "normal" range. Am I cool or near to catastrophic engine failure?
Platinum Supporting Dealership
St. Jude Donor '06-'07-'08 & '12-'13
How are you driving it ?
If you drive it like you stole it
It will burn oil and this is normal
It is a race engine after all!
But
Should not burn 2 quarts or more every 3k of normal driving ?
But
normal for a new engine to use a little. I'd change it, and keep it full instead of letting it get a qt low. It will use more when low because the condensates and blow by will be at a higher percentage. Keep it full and the undesireable contet stays at a low percentage.
I've driven a ton of new cars through their break in, ussually about 4 different ones a year for company travel. Most will take between 1/2 and 1 qt during that first 3,000. Then hardly anything after that.
When new, I like to keep a qt in the car and check it about every 1000 keeping it right to the full mark.
Originally Posted by S2K
I have to add a quart around every 2.5k miles. I now have over 10k miles on the car. Chevy says this is normal. I say...
PS Damn I wish I had bought a Vert,
Mine's burned 7 quarts in 7000 miles. Had the oil changed at 6900 and the dealer said GM's policy is to look at oil burning issues after 6000 miles as they consider that a necessary break in period. Hmmm..
I noticed they added an oil additive on the invoice as part of the oil change.
I'm not too worried about rushing to fix the problem since it'll be under warranty for awhile.
This is interesting and I will keep an eye on it. I am surprised because my C4 never burned a drop, even after 267,000 miles.
