Just curious. What are ABS of steel?
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Location: Prepare yourself, for a pride obliterating bich smack. Fairfax, VA
1 Post
St. Jude Donor '06-'07-'08
SEC > BCS 4 St. Judes '09
Originally Posted by It'sHerVette!
Cruise-In VIII Veteran
Is the 1/4" plate sufficent to maintain the stiffness of the original plate or should the 3/8" plate be used? I've already seen others post that either of the ceramic coated plates will reduce the console heat issue sufficently.
Location: Buena Park, CA I seem to have left my electrolytes with your daughter
Originally Posted by Mayonayze
skid plates. protects the underside facing mechanicals.
Originally Posted by Mayonaaaaaaze
i stand corrected. and thanks for posting that link because i had added these into my budget without much research as a protectant for when i finally lower it. ggwoody has some on his 6 i believe. i guess PM him and ask how much more "torsional rigidity" he enjoys from this tube .
Mayo, my tube has experienced plenty of torsional rigidity this weekend...even had assistance in alleviating tension at certain "stress points"
Seriously, go for the 3/8' Ceramic coated Stainless Steel plate. period. You will love it. It is worth MORE than what Elite charges for it. My cabit heat has been reduced dramatically...IE, I can not longer make Quaker oatmeal in my cupholder, and the Pop-Tarts in my center console are cold and lifeless. Breakfast will never be the same.
I did notice a marked improvement in lateral rigidity and roll in the corners. I asked Elite if this was placebo, he said "no it actually does help! Big Time!!" he said that they have noted the improvement first-hand and have gotten plenty of comments from customers.
This is by far one of the best mods you can do to your C6...and you will never see it....after installation.
1 Post
Originally Posted by GGWOODY
BUAAAAAAAAAA HAHAHAHAHAHAHA
Originally Posted by AMF
GOOD LORD! Looks like there's an unborn child in that arm.
don't you just love photoshop?
