can anyone help me pls?
Guest
Posts: n/a
Hi there. I just want to know if there is any site where i can see all models of corvette from 1998 because i can`t figure out the difference beetween c6 and c5, or c5 and z06; or if anyone can explain me the difference beetween them when i'm looking on them. Escuse my bad english. TYVM.
C2 of Year Finalist (performance mods) 2019
St. Jude Donor 03-'04-'05-'06-'07-'08-'09-10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I will start to answer and others can add:
1998-2004 are C5s and very similar in appearance. The difference is minor refinements in each model year. Coupes, verts and Z06s.
The Z06 is a "high performance" hardtop. The 2006 C6 Version has 505hp.
The C6 also comes in a coupe and vert with a base 400hp.
http://corvette-info.tripod.com/id29.html
I would also add
http://corvetteactioncenter.com/specs/
And this gives a very good history of the Z06
http://www.corvettemuseum.com/specs/...6History.shtml
Also worthy of mention and stated above, both the C5 version of the Z06 and the C6 version of the Z06 have "fixed roofs". Can't take the top off or remove the roof panel on a Z06.
The C5 version of the Z06 also had a shorter rear window than the standard coupe.
Get Some!
Hi there. I just want to know if there is any site where i can see all models of corvette from 1998 because i can`t figure out the difference beetween C6 and C5, or C5 and Z06; or if anyone can explain me the difference beetween them when i'm looking on them. Escuse my bad english. TYVM.
http://forums.corvetteforum.com/show...34&forum_id=49
And this section and the C6 Z06 section both have a FAQ post at the top that will tell you all you want to know about those models.
