Check Engine Light / CAGS Eliminator
Old Aug 30, 2005 | 11:45 AM
DaVeed's Avatar
DaVeed
Default Check Engine Light / CAGS Eliminator
I installed a Mid America CAGS eliminator at 300 miles on my C6 and I have not experienced any problems until reaching 3500 miles. The check engine light came on last week so I trudged down to the dealer to have that checked as well as the A/C problem that has been a real pain in the summer heat. The dealer said that the computer was displaying a CAGS system fault code and that it would clear when the tech disconnected the CAGS eliminator only to re-appear when he plugged it back in. So, we pulled it out of the car and all was back to normal. On the A/C side, they exhausted the refrigerant and recharged the system back to 1.1 lbs so we'll see how that works out.
I called Mid America to inquire about the CAGS device and the very nice lady (customer service rep) said she was not aware of any issues with their eliminator causing check engine lights to illuminate. Without me even asking, she offered to credit my account and politely refused my offer to return the CAGS device for their inspection. All in all she showed me a missing commodity: great customer service. Kudos to Mid America for the way they handled this. I will definitely look to them in the future for other C6 items.
Now, for the $64 thousand question: Can anyone here on the CF recommend a different brand of CAGS eliminator that has exhibited a longer life than decribed above? Thanks in advance for your assistance.
Old Aug 30, 2005 | 11:50 AM
Michrider's Avatar
Michrider
2.2K Ohm 1/2 Watt resistor from Radio Shack. Bend into a U shape and stick into the female terminals of the connector. Leave disconnected. Tape it up, zip tie it to the trans tab.
4 for .99 at Radio Shack.
I've used them on everything with an MN6 and never a problem.
Take an Ohm meter to your CAGS eliminator, I'll bet it shows open.
Old Aug 30, 2005 | 11:53 AM
Michrider's Avatar
Michrider
Here is a site with some pics.
http://www.installuniversity.com/ins...adio_shack.htm
Old Aug 30, 2005 | 11:56 AM
Braced's Avatar
Braced
I have 5000 miles on my coupe that has a WCC cags installed.
http://www.westcoastcorvette.com/sho...ail.cfm?id=785
For $20 it's worth a try. I forgot I even installed it.
Old Aug 30, 2005 | 12:03 PM
Miaugi's Avatar
Miaugi
Good advice, if the CAGS eliminator has indeed failed for some reason that would cause the issue you had. If you can have it checked and let us know.
Old Aug 30, 2005 | 12:14 PM
Boozman's Avatar
Boozman
I just hit 15,000 and no problems here I got mine from Mid America last Oct.
Old Aug 30, 2005 | 01:07 PM
c6silverbullet's Avatar
c6silverbullet
I got mine from Zip Products right here in this forum store. No problems so far (over 2300 miles). My 1-4 shift light still comes on, but I can go directly into 2nd. Good luck.
Old Aug 30, 2005 | 01:10 PM
vette-oholic's Avatar
vette-oholic
same here... zip products. 3000+ miles and no problems.
I would guess that the resistor was faulty.
Old Aug 30, 2005 | 01:23 PM
rex_l's Avatar
rex_l
Exactly correct. CAGS eliminator is not needed. The resistor is all you need. Also tape the transmission portion of the connector.
Like the other poster said ... the resistor is probably open in the one you bought.
This is less than a one beer job!
Old Aug 30, 2005 | 01:51 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
The benefit of buying one of the "commercial" skip shift eliminators from any of the Forum suppliers is that it comes with a nice dummy connector for the solenoid socket on the tranny which will prevent contamination a lot better than tape.....and for $20 it's not a big investment.
Old Aug 30, 2005 | 03:08 PM
VET4LES's Avatar
VET4LES
4200 miles
Old Aug 30, 2005 | 03:18 PM
C8-Vette's Avatar
C8-Vette
My Radio Shack 20 cent resistor is 9000 miles old and still working well!!
(sorry you can't just buy one, comes in a 5 pack for $1.00)
Old Aug 30, 2005 | 03:34 PM
dollarbill's Avatar
dollarbill
St. Jude Donor '06-'07-'08-'09-'10-'11
My Radio Shack CAGS unit (2.2k resistor) is working fine at 11,000 mi. Not bad for a buck with 4 spare units.
To Check Engine Light / CAGS Eliminator
