Screw in a Runflat
Old Sep 4, 2005 | 12:49 AM
carlb3's Avatar
carlb3
Default Screw in a Runflat
Got in the car this morning and had a nice low right rear tire pressure warning.....
Look around the tire and find a nice sheet metal screw in it....appears to possibly have been there for a while......aired it up and proceeded in to the office, she is my daily driver, no time to take in today as I am helping with the New Orleans disaster relief effort here in Houston.
anyway, to my point......
4000 miles on the tires + 1 screw.......replace it (them, both rears in this case) or patch it? and if patch it, what shop can I trust with my baby in Houston? Plan on putting on some new chromies at Corvettes of Houston soon, do they do tire repair?
Thanks for any advice and opinions.
Old Sep 4, 2005 | 12:55 AM
C6Harley's Avatar
C6Harley
Call the goodyear shops and go to the closest one that does the runflats w/ the tire pressure monitors.
You should also have a warranty on your tires, check the specifics in the little paper that came with your owners manual.
Old Sep 4, 2005 | 12:58 AM
AMF's Avatar
AMF
The Goodyear dealer can ascertain if the tire can be repaired or not and will take the appropriate action at no cost to you.
Old Sep 4, 2005 | 01:01 AM
Another Yellow's Avatar
Another Yellow
St. Jude '03-'04-'05-'06
Free repair or new tire, whatever needed, with no charge for mounting and balancing. Bring your warranty. Some Goodyear dealers have tried to charge and this is a warranty item.
Frank
Old Sep 4, 2005 | 05:36 AM
PrecisionC6's Avatar
PrecisionC6
plug it and forget about it
Old Sep 4, 2005 | 05:57 AM
ss409cid's Avatar
ss409cid
Old Sep 4, 2005 | 09:02 AM
DrHarlE's Avatar
DrHarlE
The Goodyear EMT tires have a 1 year road hazard warranty. Yes, they do have the option of repair or replace. Depending on the location of the screw, i.e. sidewall vs. tread area will determine whether it can be repaired. IMHO, the best recourse is to have the tire replaced, 2nd; tire off the rim and patched, 3rd; plugged (can't plug sidewalls). Now let's add in the factors. Driving style: Little 'Ol Lady from Pasadena; plug is fine., Drive it like you stole it; get a new tire.
**Modifier: If they decide to replace tire or repair tire off rim, having the proper tire changer is not the end of the story. The techs need to really know what they are doing so they sensors and /or rims does not get damaged. You did not mention whether you had the Z-51 option. The C6 comes with EMT's (run flats) the Z-51 has the Supercar version of the EMT. Watched my local Goodyear Factory Dealer change one. It's not easy. Then again, from what I've been reading on the board, at 10k miles they're ready to be replaced anyway.
signed,
your friend and the wheels on the Vette go round and round, round and round...........
Doc
Old Sep 4, 2005 | 09:46 AM
smarcus's Avatar
smarcus
I have been plugging run flats for years and never had a problem.
bangbgC6's Avatar
bangbgC6
I had a nail in my right rear no where near the shoulder area about 4" in from the shoulder @ about 5,000 miles.
Local Goodyear dealer maintained that the tire couldn't be repaired, not just this tire but any run-flat. I didn't want to argue so I took it to a local shop experienced in low-profile speed rated tires.
They fixed it with a mushroom style plug/patch. That was 12,000 miles ago and it has always maintained pressure since then.
Old Sep 4, 2005 | 11:03 AM
AMF's Avatar
AMF
Would not want to go very fast with a plug! Nothing against plugs!
Old Sep 4, 2005 | 11:51 AM
crazyeddie's Avatar
crazyeddie
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
I'm way to large to do that in a Runflat
Old Sep 4, 2005 | 01:25 PM
smook's Avatar
smook
I did this with my 2004 'vert. It's fine. Be sure to get a dealer who can work with the vettes rims. It's a special shop that can work on the rim without screwing it up.
-Bill.
Old Sep 4, 2005 | 02:14 PM
DrHarlE's Avatar
DrHarlE
Mushroom plugs worked very well in bias ply,fabric belted tires (non radials) when steel belted radials first came out there was a problem with the steel belt severing the plugs. Again, depending on you driving style there may have been enough plug left to maintain air pressure. The "plug" for radial tires was the rubber coated strips (which actually is a type of cord/rope). When this was inserted into the tire using the special glue, you were essentially chemically vulcanizing this corded material into the body of the tire.
It's been a while since I've been involved in the Tire Industry, but I will say this. These are High Performance Tires on a High Perf car. At the very least I would contact Goodyear (not the local dealer - they would use anything I would sell 'em) for their recommendations on materials and techniques that are accepted for patching/repairing EMT's. Again, it depends on your driving style. After all if it fails, you'll still be able to drive 100 miles @55 mph. I'd just hate to have it fail on me at 80+ mph on a curve.
Signed,
your friend and ...rollin', rollin', rollin', keep those tires rollin'.
Doc
Old Sep 4, 2005 | 02:20 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
Walk or ride a donkey - Less to go wrong! (Your Quote)
Old Sep 4, 2005 | 02:57 PM
catbert's Avatar
catbert
Discount Tire will fix it free - if it's fixable. They have fixed two on my C6 - one screw and one nail.
Old Sep 4, 2005 | 03:08 PM
VET4LES's Avatar
VET4LES
To Screw in a Runflat
