Alarm
Old Sep 7, 2005 | 01:17 PM
c2c4c6's Avatar
c2c4c6
Default Alarm
Last night after washing the car I pulled it into my garage and went through the normal shutdown procedure (reverse and emerg. brake and then shutdown of the engine). As I flipped open the door the alarm (horn) began to sound. My FOB would not shut it off. I then hit the ACC switch on the start button. That stopped the alarm. Is that normal? What could have caused it to sound? If I hit the door lock button once or twice while pushing the door open would that cause the alarm to sound? Or is this another C6 quirk?
Old Sep 7, 2005 | 01:33 PM
PJinNJ's Avatar
PJinNJ
Default Well
Perhaps the fob was in you right pocket or the antenna is expierencing problems or the fob is bad.
Old Sep 7, 2005 | 01:38 PM
c2c4c6's Avatar
c2c4c6
The FOB was in my pocket when the alarm started.
Old Sep 7, 2005 | 01:52 PM
Vette_DD's Avatar
Vette_DD
I'm with PJinNJ; I think the antenna system did not detect your fob as you were opening the door, even though you had the FOB in your pocket. Here's some info. from page 2-19 of the owner's manual.
Disarming the System
Always use your keyless access transmitter to unlock a
door either by pressing the unlock button on the
transmitter or by squeezing the door handle sensor
while you have the transmitter with you. Unlocking a
door any other way will set off the alarm. If your alarm
sounds, press the unlock button on the keyless
access transmitter to disarm it.
Was the unlock button on the FOB one of the buttons you tried to use to shut off the alarm?
I think pressing the UNLOCK button (inside the car) would also set off the alarm if the FOB was not detected.
Old Sep 7, 2005 | 02:07 PM
Dave@Ciocca's Avatar
0Dave@Ciocca
Former Vendor
When you went to get out of the car, was it locked? Did you have to unlock it before you opened the door?
Old Sep 7, 2005 | 02:34 PM
VET4LES's Avatar
VET4LES
Happened to me a couple of times. When I get out everything is normal, shut down properly, door's unlocked etc. I just figured the car do not see the FOB. I'm not worried about it.
Old Sep 7, 2005 | 03:10 PM
c2c4c6's Avatar
c2c4c6
I believe it was unlocked because I had just pulled in and shut down the engine. I opened the door and I do remember that I may have accidently bumped the unlock or lock button on the door (once or twice). But why should that set off the alarm?
Old Sep 7, 2005 | 03:13 PM
0Dave@Ciocca
Former Vendor
My guess is that you accidentally locked the car with the FOB while you were in the car. If you did and then unlocked the car with the button on the door, that would set off the alarm.
Old Sep 7, 2005 | 05:52 PM
It'sHerVette!'s Avatar
It'sHerVette!
St. Jude 15 Year Donor
St. Jude Donor '07 thru '25
Could something in your pocket have pushed the horn (red) button on the fob by accident?
The only way to shut it off is to do what you did. I do it all the time with my Trailblazer and have to start it to stop the flippin' horn.
Old Sep 8, 2005 | 12:10 PM
c2c4c6's Avatar
c2c4c6
I thought that you could stop it by pressing the "Unlock" button on the FOB, but that didn't seem to work. Has anyone else had that problem?
To Alarm
