Rear deck lid button
Old Sep 20, 2005 | 03:03 PM
jnets's Avatar
jnets
Default Rear deck lid button
Has anyone had problems using the hidden button to open the rear deck lid? - seems it only works sometimes. I have to use the remote when the button doesn't work. C-6 has 10,000 miles and that seems to be my only problem other than the stereo sucks.
Old Sep 20, 2005 | 03:07 PM
Pipedreams's Avatar
Pipedreams
St. Jude Donor '06-'07
Here is your problem, I documented it a while back
Hatch Button Thread
Old Sep 20, 2005 | 03:17 PM
Derail's Avatar
Derail
Works every time.
Old Sep 20, 2005 | 08:40 PM
MichaelB's Avatar
MichaelB
St. Jude Donor '06
Hatch Button Thread
Good job, Ed. Another problem explained and better understood. We appreciate it!
Old Sep 20, 2005 | 10:52 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
Hatch Button Thread
Old Sep 21, 2005 | 12:08 AM
lap1's Avatar
lap1
14K miles and no problems here. But I wonder if the switches are malfunctioning because they are used like a mechanical switch, ie, holding it on until the hatch opens... may burn out switch.
I found that touching it momentarily and waiting it popped the hatch, as it is electronic.
Cheers
Old Sep 21, 2005 | 12:48 AM
Low12s's Avatar
Low12s
From: Life isn't about waiting for the Storm to pass, it's about learning to dance in the Rain.
Like a charm
Old Sep 21, 2005 | 01:12 AM
Nel727's Avatar
Nel727
I use the button all the time.No problems @ 4100 miles.
Old Sep 21, 2005 | 06:15 AM
Z-51's Avatar
Z-51
Works for me all the time
Old Sep 21, 2005 | 07:12 AM
C8-Vette's Avatar
C8-Vette
Default hatch button
After you remove , clean an replace button, wrap some plummers clay around the inside button housing . This will keep dirt and moisture out in the future. Plummers clay is available at Home Depot. It comes in a bar. Costs just over $2.00
Old Sep 21, 2005 | 07:49 AM
vetteman22's Avatar
vetteman22
if the button sticks ,its a clear sign to order a new vette...
Old Sep 21, 2005 | 08:42 AM
Pipedreams's Avatar
Pipedreams
According to GM the new button is redesigned to hold up better
Old Sep 21, 2005 | 10:24 AM
jnets's Avatar
jnets
Pipedreams - Thanks much - great info on the button. I will take it apart tonight. Also - love your garage floor - I'm in the process of putting down some RaceDeck flooring myself and really like your design. Thanks again.
Old Sep 21, 2005 | 10:31 AM
Pipedreams's Avatar
Pipedreams
Thanks, post some pics once done
Old Sep 21, 2005 | 02:42 PM
C8-Vette's Avatar
C8-Vette
Ed,
The only problem with the new button is that Mr Goodwrench has to install it! Putting the plummers clay around the old button will do the trick. Did you order your Z06 spoiler yet??
Al
To Rear deck lid button
