Radio won't turn on
Old 09-25-2005, 10:41 PM
54greg
Support Corvetteforum!
54greg's Avatar
Default Radio won't turn on
I have the 6 stack bose radio. The last few time I started the car the radio would not turn on. After I drove for a minute or two the radio began working? Any ideas.
Old 09-25-2005, 10:46 PM
parkland_c6
parkland_c6's Avatar
Happens to me too. Did you use the other FOB or accidentally hit the second memory button. It appears it is adjusting from last settings to new ones. Scary, but normal.
Old 09-25-2005, 10:48 PM
54greg
54greg's Avatar
Thank you. I would not have thought of that!
Old 09-25-2005, 10:57 PM
Vette_DD
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
Radio and Climate Control settings get saved automatically per fob, based on which fob was used to start the car.
Old 09-25-2005, 10:58 PM
The Garage Master
The Garage Master's Avatar
This has been discussed I had the same problem. There is a software update or they replace if it isn't the FOB issue.
Old 09-25-2005, 11:09 PM
2005ArcticWhite
2005ArcticWhite's Avatar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'18,'20-'21,'24
Old 09-26-2005, 10:51 AM
Larry B.
Larry B.'s Avatar
Mine does the same thing... I have tried to figure it out... It does it at random... nothing to do with fobs restting. I drive with my fob, stop at a store and start the car... it may or may not happen. Same thing for my wife's fob. One fob. two fobs makes no difference.
Old 09-26-2005, 11:13 AM
lager99
lager99's Avatar
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
It seems to take about 30 seconds...it sucks if you shut down your car with the radio blaring and then get back in...can't turn the damn thing down.
Old 09-26-2005, 04:49 PM
9T4Z
9T4Z's Avatar
Done it to me a couple of times... I thought it was broken then turned off the car and restarted it and it was fine... weird. I was NOT aware there was a software fix for this.
Old 09-26-2005, 04:51 PM
rick229
rick229's Avatar
I'm telling you guys, it's UFO's. Check the skies.
To Radio won't turn on
Quick Reply: Radio won't turn on
