Did some DBS testing today
Old Sep 29, 2005 | 09:04 PM
Jbal's Avatar
Jbal
Mike;
Much thanks for all you have done on this isssue.
One of the very interesting posts on the DBS issue I recall related to positive CONTACT when put in reverse. Apparently, a couple of messages are sent to the ECM, which indicate all is well, & shuts down properly. I do recall the author felt this might be the problem.
Any thoughts?
Thanks-Jerry
Old Sep 29, 2005 | 09:53 PM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Originally Posted by mikeyc6
Automatics do not have column lock. Plus, I did a number of tries slapping the shifter out of R just as I was shutting down. If the reverse switch was bad, it'd have to be bad when you are shutting the car down and then it would give you all the "shift to reverse" warnings. Once the car has been shut down in R, you can take it out of reverse, put it back in again, take it out again, etc. and it will never cause a current draw.
There was one permutation that I found that would cause the car to run the battery down without the normal warnings. It is possible that this sequence has caused a DBS or two, but I wouldn't think it would be common:
(1) Shut off car in reverse and exit.
(2) Come back later and get back in to get something.
(3) Bump the shifter out of R (or have a bad R switch).
(4) Press the accessory switch to turn acc mode on.
(5) Press the accessory switch again to turn acc off.
(6) Exit, shut door and walk away.
If you do the above quickly enough, you may get out before you see the "shift to reverse" message and at least on my car, the above doesn't produce the same three horn honks that you get if you shut down initially without being in reverse. Also, the lights don't stay on like they do if you shut down without it being in reverse. This might lead people to think there is no problem yet accessory mode will stay on forever because the car refuses to return to sleep mode once accessory mode is turned on/off with the shifter in a gear other than R.
In any case, the car requires the shifter to be in reverse after two operations: (1) shutting the engine down after a normal run and (2) after turning accessory mode on and then back off. Unfortunately, the warnings seem to act a little "differently" when (2) occurs and this could be fooling people. I did get a fast ding-ding-ding that you get when accessory mode is left on as I exited after (2) but in my case, the ding-ding-ding sound didn't start until I was halfway out the door. If I exited very quickly, I could actually get the door almost shut before the ding-ding-ding started up. After the door is shut, there is no indication that the car is "locked" in accessory mode unless you peer in through the glass and look at the dash.
Mike
Interesting, I noticed a similar situation on my automatic. If I shut down the engine and then pressed the accessory mode on and then off the radio remains lit up. If I exit the car it locks normally but the radio is still lit up. (not actually on but lighted) "There is no indication that the car may be "locked" in accessory mode unless you peer in through the glass and look at the radio".
I have to reenter the car, start and then shut the car before it will shut down normally with the radio unlit.
Old Oct 3, 2005 | 04:29 AM
BlackMagik's Avatar
BlackMagik
I found out a few days ago that just pressing on the door membrane (with the car locked and no fob) would wake up the car and cause a draw of about 2 amps for about 30 seconds. I then got the idea to do some testing with a digital voltmeter attached to see what would wake the car up and for how long. The test procedures were to connect the digital voltmeter directly to the battery, look at the voltage in the "sleeping" state, and then do something (like touch the door) and record how much voltage drop there was and how long it took the voltage to come back up. Doing this allowed me to test different wake-up/sleep sequences.
The results are here
One thing I noticed is that just touching the door membrane caused a current draw that would stop after 30 seconds. Actually opening the door and closing it would cause even more current draw and for a longer period of time (1 minute). One interesting thing that I found is that if you just touch the door membrane and it doesn't open (because it is locked and there is no fob nearby), there was a steady current draw for 30 seconds. In contrast, actually opening the door and closing it would produce about the same draw for a few seconds, then a momentary "blip" of much higher current draw lasting no more than 1 second, and then back to the original current draw. This indicates that something is being "tapped" momentarily and this adds to the steady-state current draw.
I found really no difference between readings doing similar tests with relay 46 out versus in. This doesn't mean that it is not a cause, only that it appeared to do nothing in my 20 or so tests. I also found that once the car was shut down properly in reverse, you could move the stick out of reverse and test results are the same with the stick in N as long as you initially shut down in reverse. We knew this of course, this just confirms it. One interesting thing that I didn't know just because I had never tested it is the fact that if you shift to R, shut down, and then shift to N, the car is fine but if you then hit the accessory button with the car in N and turn accessory mode back off, it will ask you to place the car in reverse again after using accessory mode.
Not sure what useful information this gives, but if nothing else, maybe it gives us a way to be able to test things.
Mike
Mike,
Sounds like you have some good ideas. Add this to your list of info. I park my car with the light switch in the parking light position so when I start it and back out of the garage I don't have the HID headlights having to come on just to go back off after I back out in the light. Have DBS 3 times but the very first event with the car was this. CAr is parked in the garage, FOB is in the house far from the car. OnStar calls me and hassles me about a survey and I start the survey and then decide I don't have time for this and tell the guy I'm done. He is upset. I go out in the yard for 20 min, come back in the garage and the car is activated and parking lights are on and dash lights all lit up. I am in shock, had not heard about DBS at that time and so I get in the car and try to start it without my FOB to see if it will and it didn't. I then get the FOB and start it and shut it back down. Of course I assumed it was OnStar getting even with me (and still wonder) I am trying to find out what circuits they have access too. I am thinking about having them do a door unlock to see if that activates the acc mode. And if so, will it shut back down in 20 min? I see that the parking lights will come on with the acc position. Bottom line, I wonder if OnStar can have something to do with these cars waking up? I tried to find out how many DBS cars are OnStar cars but had no luck.
Gary
Old Oct 3, 2005 | 04:59 AM
BlackMagik's Avatar
BlackMagik
Mike,
Don't know if you have a shop manual, but I find it interesting that the schmatic for the "Steering Column Lock Control Module" was set up to apply for either an automatic or manual transmission. I can't imagine why they wouldn't want to treet them the same. Manual in reverse or automatic in Park and then lock the steering column. It was clearly set up for it so I am trying to figure out why they would stop short and not apply it. Wonder if the module is even installed in automatics. I am pawing over these schmatics trying to find the differences between Auto and Manual. Lots to look at still but that module, lock motor and associated message center is fairly significant.
Gary
Old Oct 3, 2005 | 10:01 AM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Originally Posted by BlackMagik
Mike,
Don't know if you have a shop manual, but I find it interesting that the schmatic for the "Steering Column Lock Control Module" was set up to apply for either an automatic or manual transmission. Wonder if the module is even installed in automatics. I am pawing over these schmatics trying to find the differences between Auto and Manual. Lots to look at still but that module, lock motor and associated message center is fairly significant.
Gary
This sounds like a good question for "Shopdog" to answer.
Hope he is reading these postings.
Old Oct 4, 2005 | 11:07 PM
Don Hoskins's Avatar
Don Hoskins
Some one has posted that the FOB detector sleeps until a door or hatch membrane in touched. If that is correct external RF sources should not be a problem. Mike has made a super contribution to this effort. I am now betting on the column lock not always providing an engaged signal when the computer checks following a signal for either a door or hatch membrane switch. I have seen several people reporting problems with hatch switches, maybe they, or the door switches, sometimes send bogus signals and put the computer into a loop when the column switch is not responding?
Old Oct 5, 2005 | 09:44 PM
Paulct's Avatar
Paulct
Just to clear up a few things. I think there was a poll about DBS, and Onstar seems to be unrelated. I had DBS once (no onstar or nav), and the only thing I can remember, which someone else mentioned, is that I "think" at some point I entered the car from the passenger side to get something.
I never lock the car in the garage, fobs are nowhere near. For the newbies to DBS, this is not something related to a constant small current draw due to all the electronics that occurs over weeks. Its clearly a pretty big draw, as it kills it in as little as a day or two.
I had mine for 5 months, having left it weeks at a time before first DBS.
I now have Priority Start and an Optima, so I won't get stuck again!
Old Oct 15, 2010 | 10:31 PM
KTVette's Avatar
KTVette
I"m wondering if you got a Tune if the Tuner downloaded #'s from another vehicle if there's any possible way that it could be related to DBS. I never had a problem till I got a Tune. And... my bouts with DBS, the car would not start even after charging until I disconnected then reconnected battery. I've yet to experiment, next time car won't start, before i charge the battery I will disconnect/reconnect and see what happens (if anything) Still want this re-flash PCM thing I'm hearing about.
I just switched out my FOB, see what that does.
Still love my Vette!!!!!!!!!!!1
