Start sequence
Old Oct 7, 2005 | 09:37 AM
C6-er's Avatar
C6-er
From: Just another gray haired old fart in a Corvette.
Default Start sequence
How long will the starter stay engaged if there is a mechanical issue preventing the car from starting?
Old Oct 7, 2005 | 09:55 AM
Violet's Avatar
Violet
i've wondered the same thing. when we first got the car, I was under the impression I was holding the button down to start the car. in other words, I'd keep my finger on it till the car fired up and then let it go.
it wasn't until a month of so of driving that i went to tap the starter button and my finger slipped off... BUT... the car went ahead, turned over and fired right up! i was, like, duhhh. lol the button isn't a mechanical "connection" to the starter, Violet.. you dork.
it was after that while my mind was wandering (as it often does ) ...that i thought, well gee, i wonder how long it'll turn over before it quits if the engine DOESN'T fire right up???
that being said... everything in the car is computer controlled, there must be SOME sort of "time-out" that if the engine hasn't fired the starter quits turning. someone here, like C5-Tech, will know.
Old Oct 7, 2005 | 10:26 AM
JmpnJckFlsh's Avatar
JmpnJckFlsh
I have also wondered about this. Like you, I think the computer must time-out the cranking. The owner's manual doesn't say how long it will crank...only that you should wait 15 seconds before trying again.
Old Oct 7, 2005 | 10:40 AM
C6-er's Avatar
C6-er
I guess we could pull the fuse for the fuel pump and time the starter.
Old Oct 7, 2005 | 10:43 AM
Violet's Avatar
Violet
You, sir, obviously want to know WAY more than I do.
Old Oct 7, 2005 | 10:44 AM
Miaugi's Avatar
Miaugi
Let us know what happens after you try this!
Old Oct 7, 2005 | 10:46 AM
JmpnJckFlsh
Yep...A regular dedicated scientist thirsting for knowledge.
Old Oct 7, 2005 | 10:52 AM
C6-er's Avatar
C6-er
You mean I can’t talk one of you gentlemen into this? I drove mine off the line on Tuesday so when it gets here I will try it.
Old Oct 7, 2005 | 10:59 AM
Flatbush_Harry
Guest
Posts: n/a
To date, my C6 MN6 turns over immediately with a single brief push...I haven't had to hold down the starter at all (3-1/2 mos, 1300 mi).
Harry
Old Oct 7, 2005 | 11:32 AM
JmpnJckFlsh
Harry
What he's asking is, after you push the start button, how long will the computer continue to crank the engine until it decides the engine ain't gonna start and stops cranking it.
I'm going to wait until mine "malfunctions" to find out...maybe I'll never know that piece of information, and it will make me happy not to find out. I have no intellectual curiosity about this issue.
Old Oct 7, 2005 | 11:49 AM
Flatbush_Harry
Guest
Posts: n/a
Sorry if I went off task...like you, I hope not to find out.
Harry
To Start sequence
