Run Flats
Old Oct 17, 2005 | 04:52 PM
PR2005C6's Avatar
PR2005C6
Default Run Flats
Are the C6's Run Flats self sealing? I seem to have acquired a screw that is in the tread. Air is leaking out slowly. If I remove the screw, will the tire seal itself or do I have to bring it in for repair. If the tire needs to be repaired, do you know if they are removed from the rim to do this repair?
Old Oct 17, 2005 | 04:55 PM
AMF's Avatar
AMF
The runflats are NOT self-sealing.
Old Oct 17, 2005 | 04:58 PM
VET4LES's Avatar
VET4LES
Call Goodyear for an authorized dealer for the EMT tire and get it fixed for free.
Old Oct 17, 2005 | 05:10 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
What he said, and these tires are not self healing
Also, do not remove the screw - but get to a dealer quickly.
Old Oct 17, 2005 | 05:13 PM
jim213's Avatar
jim213
Never, never remove a screw!
Old Oct 17, 2005 | 05:38 PM
Walt White Coupe's Avatar
Walt White Coupe
As said above they do not seal themselves. If you get a low pressure warning just add air to 30 psi.The tire has to be removed for them to repair it and it then has to be rebalanced. If you take it to Chevy they will charge you for the work, but if you take it to a Goodyear dealer they will fix it under the tire warranty. You may have to fight for this if you don't have the tire warranty that came with the car. In that case call Goodyear Customer Service at 800-321-2136 and they will direct the dealer to repair it under the warranty. Good luck.
Old Oct 17, 2005 | 05:50 PM
not08crmanymore's Avatar
not08crmanymore
Default Call Goodyear for an authorized dealer for the EMT tire and get it fixed for free.
i had a screw a couple of weeks ago.i had them plug it at work.all is well now.Damn,i wish i knew i could have goodyear fix it for free!!!why do they do that,anyway??anybody.??
Old Oct 17, 2005 | 05:51 PM
VET4LES's Avatar
VET4LES
Goodyear sent me to shop that refused to honor the waranty so I paid $25 and Goodyear sent me a check and it took about 2 weeks.
Old Oct 17, 2005 | 07:10 PM
catbert's Avatar
catbert
Discount Tire always fixes flats FREE - nail, screw whatever.
Old Oct 18, 2005 | 03:26 AM
gota07's Avatar
gota07
Cruise-In VIII Veteran
Call GoodYear cust service and send them your receipt to get reimbursed.
Old Oct 18, 2005 | 09:49 AM
rm50's Avatar
rm50
2020 C8 of the Year Finalist - Unmodified
I picked up a nail. The run flats are not self sealing. I went to an authorized goodyear dealer and showed him the warranty. The nail was taken out and the tire fixed. Excellent service.
To Run Flats
