C6 shifter
Old Oct 25, 2005 | 11:28 AM
Sincity's Z-51's Avatar
Sincity's Z-51
Default C6 shifter
Any body have trouble when your at a light and your waiting for it to turn green, and when you push the clutch in and try to go to first gear it hangs up and you look like an a** at the light? reverse as well, I have 10k on my car now, so it is broke in, my Q is, What? is a good after market shifter for the C6, that is a grate proformer and smooth.
Old Oct 25, 2005 | 11:31 AM
gilly6993's Avatar
gilly6993
St. Jude Donor '08
glad I'm not the only one with this prob....I shift to second then back into first but it's very annoying.....
Old Oct 25, 2005 | 11:34 AM
VET4LES's Avatar
VET4LES
Check your owners manual. It says it is normal. It will give you a percent of times that is normal. Mine does it once in awhile when first started. I am sure a new shifter will not correct the problem.
Old Oct 25, 2005 | 11:37 AM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Shifting from a Stop
Your dilemma has been reported by many and is common in all standartd transmissions. It has nothing to do with the shifter. It’s the gear teeth not lining up properly.
Simple fixs:
1. Just cycle the clutch.
2. As you’re coming to a stop, put it in 1st gear.
Old Oct 25, 2005 | 12:11 PM
ttomczak's Avatar
ttomczak
St. Jude Donor '06
I have the B&M on mine and like it so much better than the stock shifter, however, it will not do anything on the 1st gear problem...
Old Oct 25, 2005 | 12:19 PM
Mocoso's Avatar
Mocoso
Simple fixs:
its common in all transmissions... cycle the clutch - you can avoid the "looking like an ****" by putting it in 1st when the cross traffic light turns yellow
Old Oct 25, 2005 | 12:42 PM
dollarbill's Avatar
dollarbill
St. Jude Donor '06-'07-'08-'09-'10-'11
All manual transmissions have this problem from time to time. It is a gear alignment problem that can be fixed if you put it into first just as you roll to a stop at the light. It will become a habit and you will never lok like a dork again! Bill
Old Oct 25, 2005 | 12:43 PM
mforman42's Avatar
mforman42
The problem is the large gears (high mass) required to manage all the torque. The gears are hard to speed up or slow down to mesh properly. If you put the car in first while it is still moving slowly, it is much easier, because the gears are rotating and the synchros have less work to do.
Old Oct 25, 2005 | 12:47 PM
Buffy's Avatar
Buffy
I find that this isn't a problem if I drop the clutch and put it into first pretty much in one motion, as if I were shifting gears. It's only a problem if I dwaddle around by pushing the clutch in, pausing, then putting it into first. I think that by doing it quickly the gears are still spinning, and they sync up. Trying to put it into gear with both sides at a dead stop may block as the shoulders of the teeth run into each other.
Old Oct 25, 2005 | 01:08 PM
vinsvette's Avatar
vinsvette
Simple fixs:
I have almost 4,000 miles on mine and It still happens. I don't remember it happening on my 01 C5 6spd as often as it does on my C6.
Old Oct 25, 2005 | 01:20 PM
rmp's Avatar
rmp
Default If you put into first prior to stopping
then you will be stuck with your foot on the clutch for the entire duration of the light which can get tiresome if the clutch has a stiff spring. Is that what you mean or are you saying that stopping in first aligns the synchros so it shifts into first easier when you start?
Old Oct 25, 2005 | 01:24 PM
mforman42's Avatar
mforman42
In order to make it easy to shift into first, you have to leave it there for the duration of the stop. Quite frankly, the clutch is so light on the C6, that I can't imagine why it would be an issue. Even for this old guy, I have no problem. Now if this were like the mid-60s muscle cars, I'd understand not wanting to hold the clutch in.
Old Oct 25, 2005 | 03:53 PM
Lowlead's Avatar
Lowlead
Old habits die hard... I never spend any more time holding the clutch in than I have to in order to prolong the life of the throwout bearing. Even though the bearing is cheap (or it was in the old days) it's just such a b1tch to replace.
Old Oct 25, 2005 | 03:59 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
I think if you put it into gear before a complete stop you can pull it into neutral while waiting for the light as the syncros are then already lined up. (That might have been a run on sentence.)
Old Oct 25, 2005 | 04:01 PM
Shrike6's Avatar
Shrike6
Somba master
Cruise-In 7, 9 & 12 Veteran
Wounded Warrior Escort '11
St. Jude Donor '07-'08-'09-'10-'11
Yeah, that's what I do and I have had no problems.
GM
Old Oct 25, 2005 | 04:02 PM
70454's Avatar
70454
Shifting to first and then neutral at a stop sounds like it makes more sense. I also have a 70 big block with a REAL stiff clutch. Sitting at a light with my foot on that one sucks. I've got one big leg (left) from driving that beast.
Old Oct 25, 2005 | 04:26 PM
JmpnJckFlsh's Avatar
JmpnJckFlsh
I believe there is a TSB or some kind of service bulletin out for this common problem. If you have problems shifting into first gear more than 20% of the trys (I believe this is correct), GM will repair the transmission. Whether or not the annoyance is worth letting Mr. Goodwrench tear your new trans apart is a personal decision.
To C6 shifter
Old Oct 25, 2005 | 04:41 PM
AceVentura's Avatar
AceVentura
Same problem. My 2005 is having the trans repaired and should be finished sometime this week. There IS a problem with first gear and GM WILL repair it.
J
Old Oct 25, 2005 | 04:47 PM
70454's Avatar
70454
J
Do you or anybody else here have the TSB for this issue?
Thanks.
Old Oct 25, 2005 | 07:17 PM
AceVentura's Avatar
AceVentura
Thanks.
Here you go!! http://forums.corvetteforum.com/show...t&forum_id=101
