DRL out again
There is a second wire, because the bulb is a dual filament bulb. But that second wire is for the dimmer of the two filaments, which serves as your parking lights. That is on a separate fuse, but it won't help us with the DRL/turn signal problem.
(Of course there's a third wire too, that's common ground for both filaments of the bulb.)
But if the bulb snaps securely into the socket, and the socket doesn't appear burnt, changing the harness is a waste of time and effort. Just use some bulb grease on the replacement bulb (improves heatsinking), and all will be as well as can be expected in a design that continuously burns a bulb which is only designed by the bulb makers for intermittant operation.
If not thanks for the info
Even if you adjust the switch before starting up you will have no lights unless you turn them on manually. Auto is much easier to do but now you have to worry about the low beams along with the DRL's
I'm wondering about Shopdog's answer since it appears that all the new GM vehicles are running this DRL light. If he's right, then GM has a huge problem.
