Lighting Mod
Old Nov 4, 2005 | 09:32 PM
clambros's Avatar
clambros
Default Lighting Mod
Reading thru some of the threads here, I stumbled across a link for an aftermarket lighting vendor (Hoen). I liked the idea of having the high beams and driving lights match the "color" (temperature) of the HID lights in the C6. I decided to give it a try; the kit to replace high beams and driving lights only cost me $67.
Installation wasn't too bad .. Drivers side approx 45 minutes .. Passenger side 30 minutes (I knew how to take apart the inner-fender wells, the 2nd time )
Overall, I was really pleased with the results .. I'm attaching some pics taken after replacing the Driver's side, but prior to the passenger side.
Sorry, no pictures of the install
Driving Lights:
High Beams:
Old Nov 4, 2005 | 11:02 PM
jweek's Avatar
jweek
looks great - thanks for the pics! did you have to remove the front wheels?
Old Nov 4, 2005 | 11:16 PM
dark_phantom's Avatar
dark_phantom
From: Central Florida. Black Sheep Squadron Member. 465 rwhp & 477 rwtq
Cruise-In VIII Veteran
St. Jude Donor '07
I was thinking of doing the same thing. Is it better to see with the new light? Are there instructions on how to install them? Thanks.
Old Nov 5, 2005 | 12:35 AM
clambros's Avatar
clambros
Thank you .. Luckily, no .. I was able to turn the wheel, to its right & left most positions, and remove the trim pieces that allow access to the headlamps and driving lights.
IMHO, its easier to see. The "whiter" light seems to make a difference. Unfortunately, the Hoen kits have no instructions However, the install isn't too bad. If you look inside your wheel well you will see a rubber cover directly behind the headlights. Not too bad to remove. The driving lights are little more of a PITA. For the driving lights, more (and larger) panels have to be removed / loosened to allow access to the bulb.
To Lighting Mod
