Welding Advice Needed...
Old Nov 13, 2005 | 07:40 PM
rclark's Avatar
rclark
Default Welding Advice Needed...
Need some advice from anyone with a background in welding. I purchased a used set of GHL’s for my C6 from someone. I just realized that the two one inch welds (one on each side of each can) that hold the left and right sides together are cracked almost halfway down. Probably happened when it was shipped. I need to get these welded and wanted to know if there’s anything I should be looking for or asking when I take it to a welding shop. I don’t want corrosion on the welds 6 months from now.
Old Nov 13, 2005 | 09:03 PM
rclark's Avatar
rclark
someone's gotta know.... ttt
Old Nov 13, 2005 | 09:56 PM
shopdog's Avatar
shopdog
If the welds cracked, they weren't done properly the first time. When a weld is done right, the metal beside it will tear before the weld itself will fail.
A correct repair will start by completely grinding out the faulty welds and starting with clean metal. The preferred process is TIG, and the preferred filler is Hastalloy. Be sure the weldor properly passivates the HAZ (Heat Affected Zone) after doing the repair (nitric acid pickle), otherwise the weld zone will rust.
Note that a proper repair can be done with MIG (use 316L filler wire), but the entire piece will need to be preheated before welding and cooled slowly in vermiculite to prevent hot short cracking of the weld as it cools. Hastalloy is high nickel, and lets you successfully do the repair without as much worry about hot short cracking. But you can't get MIG wire in that alloy.
Old Nov 13, 2005 | 10:16 PM
rclark's Avatar
rclark
Thanks for advice... gonna try to get them fixed tomorrow.
Unfortunately, GHL's warrenty is non-transferable. I should have bought these new. They would have cost me the same new by the time I'm done... and I would have had a warrenty. Live and learn.
To Welding Advice Needed...
