C6 Nav - POS.
Now, I didn't know how close/far the place was to Philly proper as it's a new place this year - so I figured the Nav would be sending me the best way. Sometimes I even preview the whole turn list to check, but for the life of me I cannot ever remember how to do it on this crap system.
1. When you pull up a POI, there's no way apparently to check the address to be sure it's the right one. (When I sorted out where I should be, I was worried it gave me the wrong POI)
2. To pull up the turn list for the whole trip is buried way too deep.
3. Apparently the "Quick" route doesn't take into consideration when a full highway cuts off and turns into a 2-lane surface street through towns and residential. (Route 30 in Lancaster and east, FYI)
I even called onstar to see if they could get me to an 8-lane blacktop from where I was, and they said they couldn't unless I upgraded my package for $$. (Note: I've used onstar to find things I couldn't find with the Nav once before)
I want my $2xxx back, dammit. I'll get another Garmin. I'm going to rip this thing out of my dash.
Mike
Mike
It was on highways - matter of fact, I had it on allow everything except freakin Ferries.
Here's something that might help you as far as POI's are concerned. You can use the phone number of the location you want to go to if you have it. Many of the POI's have the phone numbers of those locations so if you get a hit with the correct phone number to where you are going, you know you have the right location.
Personally, I don't have much of a problem navigating through the menus on the system. It takes a little time but it's not that bad. I always use the Quickest route for all my destinations. Using Shortest or Normal can give you some extremely odd routes to follow. Make sure you are in the same Region for your destination. If your destination is in a different region, you should change to that region and THEN plot your guidance. Example: If I were leaving California to drive to a location in Washington DC, I would change the region to the one that covers Washingtion. Then I would plot my route.
One more tip is to have the system reroute to your destination AFTER you have started following the guidence. In other words, let's say you've set up a route to a destination and you have been following the route for a few miles. I've found that if you do a ReCalculate, the system will sometimes give you a better route to your location. This is especially true for long trips. I recently did a 400 mile trip and started my guidence from my garage. Once I got down closer to my destination (about 100 miles away) I asked for a Recalculate. The system gave me a slightly different route that eliminated about 22 miles of unnecessary roads - a more direct route.
I have used other GPS units and have found this recalculate function to be effective in all of them at one time or another.
At this point, my only gripe about my NAV system is that the disc they gave me was outdated by about four years. I know the new version 2 disc has better information, at least for the area I live in.
Hang in there! Check this link for more information.
http://forums.corvetteforum.com/show...ce&forum_id=74
GM
Mike
Mike
