C6 Design problems
Old Nov 22, 2005 | 07:03 AM
Czonio's Avatar
Czonio
Default C6 Design problems
Below is the list of problems that came from the 05' model, has any of these been fixed for the 06'?
From the FAQ:
Recalls/ Service Bulletins
Dash "hoot" "groan" from under dash: http://forums.corvetteforum.com/sho...d.php?t=1040150
Blocked first gear shift http://forums.corvetteforum.com/sho...41&forum_id=101
A/C blowing hot preliminatry information bulletin: http://forums.corvetteforum.com/sho...178&forum_id=74
Brake Squeal bulletin and fix: http://forums.corvetteforum.com/sho...114&forum_id=74
Crank Pulley issue VIN numbers: http://forums.corvetteforum.com/sho...647&forum_id=74
Dead batteries: http://forums.corvetteforum.com/sho...23&forum_id=101
Fuel Sending Unit: http://forums.corvetteforum.com/sho...d.php?t=1060074
Crank pulley bolt TSB & info: http://forums.corvetteforum.com/sho...d.php?t=1038771
Crank pulley complaints: http://forums.corvetteforum.com/sho...ost15501468 69
6-speed snap ring recall: http://forums.corvetteforum.com/showthread.php?t=930805
VINs in snap ring range: http://forums.corvetteforum.com/showthread.php?t=932613
Brake line safety recall: http://forums.corvetteforum.com/sho...ighlight=recall
http://forums.corvetteforum.com/showthread.php?t=949354
Known issues (not experienced by all):
Rear Axle seal failures: http://forums.corvetteforum.com/sho...546&forum_id=74
Brake line failures: http://forums.corvetteforum.com/sho...d.php?t=1113860 http://forums.corvetteforum.com/showthread.php?t=927500
Squeaks and rattles: http://forums.corvetteforum.com/sho...d.php?t=1045781
Trunk button sticking & repair link: http://forums.corvetteforum.com/sho...100&forum_id=74
A/C blows hot air: http://forums.corvetteforum.com/sho...d.php?t=1117263
A/C fix: http://forums.corvetteforum.com/sho...361&forum_id=74
Fuel Sending Unit / Fuel warning on DIC: http://forums.corvetteforum.com/sho...d.php?t=1060074
Fuel pump connector failure: http://forums.corvetteforum.com/sho...d.php?t=1116191
Convertible power top: http://forums.corvetteforum.com/sho...d.php?t=1055828
Cracking Z51 rotors: http://forums.corvetteforum.com/sho...d.php?t=1046511
Overfilling fuel tank gives Engine Light: http://forums.corvetteforum.com/sho...d.php?t=1042223
Cold Weather window indexing: http://forums.corvetteforum.com/showthread.php?t=973590
CD Changer bug: http://forums.corvetteforum.com/showthread.php?t=900908
Dead batteries - bad relay:
Dead batteries and manual tranny: http://forums.corvetteforum.com/showthread.php?t=928291
Intermittant electrical problemshttp://forums.corvetteforum.com/showthread.php?t=924597
Front License bracket: http://forums.corvetteforum.com/showthread.php?t=925949
Brake squeal after washing: http://forums.corvetteforum.com/showthread.php?t=922848
Aftermarket bracket: http://forums.corvetteforum.com/showthread.php?t=915341
Incorrect Air Filter # in manual: http://forums.corvetteforum.com/showthread.php?t=925171
Loose crank pulley: http://forums.corvetteforum.com/showthread.php?t=919069
http://forums.corvetteforum.com/showthread.php?t=940446
Water in rear view mirrors: http://forums.corvetteforum.com/showthread.php?t=924155
F55 suspension inoperable: http://forums.corvetteforum.com/showthread.php?t=903703
Manual tranny chattering: http://forums.corvetteforum.com/showthread.php?t=921011
NAV locking up: http://forums.corvetteforum.com/showthread.php?t=920242
Intermittent rear hatch open: http://forums.corvetteforum.com/showthread.php?t=917850
Brake squealing: http://forums.corvetteforum.com/showthread.php?t=916234
Missing HOMELINK: http://forums.corvetteforum.com/showthread.php?t=916057
Difficulty programming HOMELINK: http://forums.corvetteforum.com/showthread.php?t=956591
Window indexing prob: http://forums.corvetteforum.com/showthread.php?t=931055
Tire pressure discrepancy: http://forums.corvetteforum.com/showthread.php?t=915838
Orange peel: http://forums.corvetteforum.com/showthread.php?t=915802
http://forums.corvetteforum.com/showthread.php?t=807721
Loose plug wire: http://forums.corvetteforum.com/showthread.php?t=914975
Poor rear viz: http://forums.corvetteforum.com/showthread.php?t=913257
Wavy rear glass: http://forums.corvetteforum.com/showthread.php?t=911082
Squeaky roof: http://forums.corvetteforum.com/showthread.php?t=906606
Carpet fit’n’finish: http://forums.corvetteforum.com/showthread.php?t=913121
Locking seat belt: http://forums.corvetteforum.com/showthread.php?t=912562
Scraping: http://forums.corvetteforum.com/showthread.php?t=908448
Military time in radio: http://forums.corvetteforum.com/showthread.php?t=907312
Air Bag stickers: http://forums.corvetteforum.com/showthread.php?t=907815
Ticking soundhttp://forums.corvetteforum.com/showthread.php?t=923699
MISC problem list: http://forums.corvetteforum.com/showthread.php?t=913864
Door gaps and adjustments: http://forums.corvetteforum.com/sho...ost15487108 68
Z51 directional rotors mounted on wrong side: http://forums.corvetteforum.com/showthread.php?t=939034
Hood Emblem Peeling: http://forums.corvetteforum.com/showthread.php?t=940588
Clicking noises while driving, troubleshooting tips: http://forums.corvetteforum.com/showthread.php?t=940930
Broken door buttonhttp://forums.corvetteforum.com/showthread.php?t=940738
Passenger door rattle: http://forums.corvetteforum.com/sho...ost15487757 11
Old Nov 22, 2005 | 07:43 AM
Another Yellow's Avatar
Another Yellow
St. Jude '03-'04-'05-'06
Nope, keep your C5.
Old Nov 22, 2005 | 08:33 AM
StanNH's Avatar
StanNH
The "military time in radio" is the really big one. I don't think that's been fixed for 2006. It's my understanding that as long as your car displays military time, you can be called up to active duty and shipped out to serve in Iraq for up to 9 months. That alone should keep you from buying a new C6.
BTW, too many of the items in that list are one time or isolated complaints and/or observations to be of any value. The few major issues have all been addressed either during the 2005 production run or with the start of the 2006 run. The only lingering issue for the 2005 cars sems to be the dead battery gremlin and that will hopefully be dealt with by GM in the near future.
Old Nov 22, 2005 | 08:40 AM
FastMover's Avatar
FastMover
From: Tellico Plains, Tn "Wolf" Official Corvette Guard Dog
Cruise-In II Veteran
Cruise-In III Veteran
Originally Posted by Another Yellow
Nope, keep your C5.
Old Nov 22, 2005 | 08:43 AM
LJD51's Avatar
LJD51
From: North Strand, NMB, SC; Retired x 2 (US Army: 70-90 AD) (US Army: 91-16 DAC); yea, I'm old.
Nope, keep your C5.
or buy a rice burner...
Old Nov 22, 2005 | 08:45 AM
CROWVETTE's Avatar
CROWVETTE
I feel left out. Have not experienced one of the problems.
Old Nov 22, 2005 | 09:14 AM
Buffy's Avatar
Buffy
I think the air bag stickers are still an issue.
Old Nov 22, 2005 | 09:23 AM
SA HEAT's Avatar
SA HEAT
Me neither
Old Nov 22, 2005 | 09:25 AM
not08crmanymore's Avatar
not08crmanymore
Default recalls
The only Recalls I ever got was The voice in my head recalling me to drive the C6,Z51 more!!
Old Nov 22, 2005 | 09:27 AM
jdavis's Avatar
jdavis
This thread has the aroma of a troll. Too much effort appears to be made to make things seem worse than they actually are. Besides, no single car is likely to experience all those faults. I think that he is listing everything that has reported on many individual cars, not constant flaws on all '05 Corvettes. With over 30K C6s produced, I suspect that there are far more satisfied owners than this list would "appear" to suggest.
mountainlover's Avatar
mountainlover
8 weeks and 4K miles on 2006. Not one of those problems.
Old Nov 22, 2005 | 09:29 AM
fts's Avatar
fts
Originally Posted by SA HEAT
Me neither
Me neither...maybe I should complain to GM.
Old Nov 22, 2005 | 09:40 AM
Derail's Avatar
Derail
The water in rear view mirrors, I can't believe GM hasn't fixed this yet.
Old Nov 22, 2005 | 09:42 AM
Nel727's Avatar
Nel727
Old Nov 22, 2005 | 10:01 AM
jdoelger's Avatar
jdoelger
Have had only the fuel sending unit problem with my '05-No one has had all those problems in one car...
Currently having the sqweaky brake problem on my '05 Acura RL-
Oh, I forgot, only GM screws up.............
Old Nov 22, 2005 | 12:42 PM
jim213's Avatar
jim213
Originally Posted by Nel727
Exactly.
Old Nov 22, 2005 | 12:53 PM
rosemaryburm's Avatar
rosemaryburm
From: Heaven, for the climate; Hell, for the company
The C6 is soooo over. We've all read all these posts, and we are all just totally fed up. We were just waiting for Motor Trend to announce the Car of the Year. We are arranging a group purchase of white Civics with grey velour seats. Want in?
To C6 Design problems
Old Nov 22, 2005 | 01:00 PM
SA HEAT's Avatar
SA HEAT
Count me in. I've got a 8" diameter fart-can, some wicked ground effects, and a big *ss trunk wing just ready to bolt on.
Old Nov 22, 2005 | 01:20 PM
2vettes's Avatar
2vettes
9 months; 5,200 plus miles; no problems.
Old Nov 22, 2005 | 01:23 PM
jschindler's Avatar
jschindler
Damn, I'm glad I didn't see that list before I bought my first C6....or my second one, for that matter.
I've owned two 2005 C6's, and neither one of them has been back to the shop!
