Is there something wrong with my vehicle or is this common to all? I cannot dim the illumination all the way to "off" using the procedure outlined in the owner's manual.
Yeah, the manual is not clear one this one. You have to turn and hold the switch to brighten or dim the instrument panel lights.
This is a dimmer switch...it dim all the way from almost gone to bright. I have to hold mine (nornal) and zing it back and forth while i put pressure on the right hand side.
My friend's one work perfectly fine...I will get mine replaced
The dimmer switch is a very poor design. It is very frustrating to use and it takes one's attention away from his driving. Why the switch was made that way is beyond me.
And don't accidentally push in on the switch. That will turn on your interior lights without giving you any indication that the switch is actually on. I wonder if this switch was designed as a practical joke.
